8 members (Donf, Gdads51, 55shaker, FAST55, Ponchogl, Wickedbass, Cosmo, Hanks custodian),
66
Mod | | | Forums66 Topics128,065 Posts1,055,868 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 136 | Hello everyone -
I have just sanded down the outside of my 55 rear fender and it looks great! I used a DA sander and a Norton flap disk. Now I am cleaning up the inside of the fender. Due to the curves I will not be able to use the same approach for the whole thing.
Does anyone think using a siphon sandblaster set at 100 psi will cause any warpage?
Aren't the professional sandblasters using huge psi numbers?
Ross | | | | | Joined: Jun 2005 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 128 | ah you'll be alright on the inners in the curves,pretty hard to warp a curve! hmmmm! these old trucks are really thick also,pretty hard to warp these girls unless your in the middle of a flat panel holding the blaster in one spot for too long ( five seconds or more) give or take! and it's not the psi that does the warping .It is the heat created from friction, sand meeting metal at a very high speed!well something like that!  | | | | | | Anonymous Unregistered | | Anonymous Unregistered | The 100psi should not warp the fenders as the contour provides good support. The only problem I see is the 100PSI may not be enough. I would use a scrapper to remove the heavy stuff and then one of those fiber stripping disks on a drill for what is left. Unless you are trying to get a show car finish on the inside surface this should do the trick. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I sandblasted both bedsides of my truck using 175 psi, didn't have any warpage issues. The real trick is to keep moving, don't stay on one spot too long. That helps keep the heat from building up in one area.
Bill Burmeister | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | I have to tell you guys, heat has nothing to do with it, it is "mechanical compression". I used to think it was heat as well, after blasting in the dark and seeing the sparks as the sand hit. Sparks equal heat, heat warps metal.
But after being told what really causes it, I checked for myself. Sure enough, I sandblasted some metal and felt it, it was actually cooler! Yep, the air blowing on it cools the metal!
Mechanical compression is where the sand particles are acting like tiny hammers putting microscopic dents in the metal. Each of these dents is stretching the metal just as hitting it with a hammer would. Put a zillion tiny dents stretching the metal you are going to have warpage.
I know it is possible to sand blast sheetmetal and not damage it. However, I have seen such HORRENDOUS damage caused by sandblasting I never recommend it.
We are not talking "Dang, I messed up and now I have more work" kinda damage. We are talking "HOLY %#@ I &*%#@ED IT ALL UP AND HAVE TO THROW IT AWAY" kinda damage.
If you do it, be VERY careful.
Brian
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
| | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | 1stproject, I had the entire body, fenders, doors, hood, frame of my 49 sub sandblasted locally at a very reasonable price. No warpage. If you go this route you need to find someone who has experience in doing this. I found after trying the stripper, DA sander and elbow grease method that it was taking forever. IMHO blasting is the way to go and it does a much better job. It worked for me. Weeds | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | Like I said, even the pros can DESTROY stuff. I had a guy do it, I know. He DESTROYED a 1928 Buick door for me. And this guy was an owner of a sand blast company that had did a lot of work for me in the past. I had never gave him something like this before but with everything in the past, pickup beds and tons of other stuff. But that door, holy crap it was JUNK when he got thru with it. I'm sorry, unless I REALLY knew the guy could do it, there is no way I would hand something to someone to sand blast. Now, "Media" blasting with walnut shells or plastic beads, that is a different story. It won't harm a thing. This is just one of the treads I have seen on the subject.. http://www.chevelles.com/forums/showthread.php?t=95691 Brian
To start with, thanks for the feedback. After reading all of the posts, I see there are a lot of varying opinions.
I can not afford to buy all "new" parts, and I don't want to use my limited funds on a professional, so I guess I am going to do it and just keep the blaster moving. (I have heard and read a lot of stories about professional sandblasting companies destroying parts. Scary!)
Thanks again! I will post how it goes.
Ross | | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | I stripped one fender inside & out with DA's, roloc's, wire brush, liquid stripper and anything else I could find. It was a pain. I took the other fender, a bed side and the bed steps to the local media blaster. They bake first, then glass & plastic bead (not sure of the order). The parts came back rust free, but were much more susceptible to surface rust than the part I did. I ended up have to clean them up just to get rid of surface rust before painting and that was less than a week. I can't see where anything has warped and would do that again, but I'll be ready to paint ASAP and take one part at a time. | | | | | Joined: Jan 2007 Posts: 50 Member | | Member Joined: Jan 2007 Posts: 50 | Use fine grit sand. 100 psi will do it if you get to a spot you can't get clean quickly move on then scrape and touch up again. Sand blasting is easier than typing!
restoring a 1946 coe wrecker.
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I would say check out your sanblast guy before taking parts to him , I did a little background check on the 2 local shops in my area an found 1 was terrible the other nothin but good words ....so I stopped in an talked to the owner , an I told him what i wanted done ...he said he done Lotts an when he told me he would not touch the underside of my hood but would blast the top side an explained to me how the reinforcement ribs under the hood when blasting around them is a very tricky process and he couldnt gaurantee against warping it, I knew I had someone with expierience....fenders doors & hood came out very nice ! | | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | For whatever it's worth, this entire truck was sandblasted by me, interior, exterior and frame. I had no problems. See pics! | | |
