7 members (tclederman, Woodcmiami, Hotrod Lincoln, Otto Skorzeny, 2-Ton, bobfake, 1 invisible),
41
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,091 Posts1,056,034 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 18 'Bolter | | 'Bolter Joined: Apr 2013 Posts: 18 | hi all i have a 1934 Chev one and a half ton try truck and the rear brake drums are badly worn is there a way to refurbish these drums to bring them back to serviceable as I have not been able to find replacement drums for the vehicle
1934 1-1/2 ton truck (Australia)
| | | | | Joined: Mar 2014 Posts: 4,485 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,485 | Are they worn past the point of grinding them? Jon
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | What is your wheel bolt pattern? GM 14 bolt rear axles come in various widths, 8 on 6.5 which you probably do not have-adapters are easily made. Dana 70 and 80 come with 5/10 bolt patterns.
Ed
| | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | psmith, Flame spraying is a process that is used to deposit metal on worn/damaged surfaces and for cosmetic and rust prevention purposes. http://www.precisioncoatings.com/what-is-thermal-spray.htmlThe challenge is finding someone who has even heard of it if you are in a rural area.
Ray
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you haven't tried making a parts wanted request at the VCCA site, that might be a worthwhile effort. | | | | | Joined: Apr 2013 Posts: 18 'Bolter | | 'Bolter Joined: Apr 2013 Posts: 18 | Hi the bolt pattern is 10 boltson the back with a hubcap ring at the front with a 5 bolt pattern the ware on the drums is almost to the point tht i is to far to grind so was looking to see if there is a way of building it back up
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | So with the 10/5 bolt pattern, you are limited to Dana 70 or 80, unless can make steel wheel adapters.
Ed
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ........just a thought. I wonder if the guys who weld and build up cranks and then turn them back down have a set up where they can do that? I won't be in town for a few weeks or I would ask the guy who always did mine and my brothers crankshaft work. Like I said, just a thought if there is no other way. | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Alvin, I'm pretty familiar with the "submerged arc" process used on crankshafts, and I doubt if it would be adaptable to brake drums. A series of overlapping weld beads about 1/4" wide is applied to a crankshaft, then the surface is reground to the correct diameter. The amount of welding necessary to build up a brake drum surface would be slow and expensive, and there would probably be a lot of distortion involved due to heat warping. It would probably be better to find a replacement drum of the correct diameter and width, and do some sort of machining/welding process to swap centers. Less welding, less distortion, and a much better chance of success, IMHO. Jerry
