0 members (), 155 guests, and 4 robots.
Topics128,110
Posts1,056,241
Members48,437
#1270159 06/24/2018 9:46 PM
hi all i have a 1934 Chev one and a half ton try truck and the rear brake drums are badly worn is there a way to refurbish these drums to bring them back to serviceable as I have not been able to find replacement drums for the vehicle
1934 1-1/2 ton truck (Australia)
Moderator, Electrical Bay
Are they worn past the point of grinding them?
Jon
~ Jon
Crusing in the Passing Lane
What is your wheel bolt pattern? GM 14 bolt rear axles come in various widths, 8 on 6.5 which you probably do not have-adapters are easily made. Dana 70 and 80 come with 5/10 bolt patterns.
Ed
Y
yar Offline
Y Offline
psmith,
Flame spraying is a process that is used to deposit metal on worn/damaged surfaces and for cosmetic and rust prevention purposes.
http://www.precisioncoatings.com/what-is-thermal-spray.html
The challenge is finding someone who has even heard of it if you are in a rural area.
Ray
If you haven't tried making a parts wanted request at the VCCA site, that might be a worthwhile effort.
1951 1 Ton Completed
Hi the bolt pattern is 10 boltson the back with a hubcap ring at the front with a 5 bolt pattern the ware on the drums is almost to the point tht i is to far to grind so was looking to see if there is a way of building it back up
' Offline
Here's a company in Australia that does spray welding .
Maybe you should have a conversation with them .
link
http://qspengineering.com.au/electric-arc-spraying-system/#
1954 3600
Now cruising in
The Passing Lane
So with the 10/5 bolt pattern, you are limited to Dana 70 or 80, unless can make steel wheel adapters.
Ed
........just a thought. I wonder if the guys who weld and build up cranks and then turn them back down have a set up where they can do that? I won't be in town for a few weeks or I would ask the guy who always did mine and my brothers crankshaft work.
Like I said, just a thought if there is no other way.
Alvin, I'm pretty familiar with the "submerged arc" process used on crankshafts, and I doubt if it would be adaptable to brake drums. A series of overlapping weld beads about 1/4" wide is applied to a crankshaft, then the surface is reground to the correct diameter. The amount of welding necessary to build up a brake drum surface would be slow and expensive, and there would probably be a lot of distortion involved due to heat warping. It would probably be better to find a replacement drum of the correct diameter and width, and do some sort of machining/welding process to swap centers. Less welding, less distortion, and a much better chance of success, IMHO.
