1 members (Hush),
81
Mod | | | Forums66 Topics128,187 Posts1,057,212 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#12698 05/10/2005 3:36 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | How many quart of oil does it take to fill a 235? I did my first oil change and I put 5 quarts in it but its still way to low, its barley on the end of the dip stick. I haven't warmed up the motor yet, could this be why? I looked thought the Shop Manual but I couldn’t find anything about how much oil to use. I did fill up the ail filter canister. I fill like an idiot for having to ask this  | | |
#12699 05/10/2005 4:29 PM | Joined: Jan 2004 Posts: 255 Member | | Member Joined: Jan 2004 Posts: 255 | I put 5 quarts in the oil pan and 1 more in the filter canister if you have one. It doesnt read exactly right on my dipstick, but I know where full is by the specs. Ralph | | |
#12700 05/10/2005 5:12 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | 6 quarts sounds good. Do you have to warm up the engine before it reads correctly | | |
#12701 05/10/2005 6:21 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | My drivers manual (glovebox copy) says 5 quarts. | | |
#12702 05/10/2005 6:30 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Are you sure its a 235? Some GMC motors take eight quarts.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#12703 05/10/2005 6:53 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | It seems that definitely more than 5 quarts came out. It looks like a 235 has the 4 bolts on the valve cover. Single carter carb. Six cylinder. | | |
#12704 05/11/2005 3:44 AM | Joined: Dec 2004 Posts: 20 New Guy | | New Guy Joined: Dec 2004 Posts: 20 | I have an old 235 ('48) splash oiler in my '51 and it takes 8 quarts. First time I changed the oil and put in 5 quarts, it baffled me as well. If it's got the original dipstick, keep utting oil in until it reads full on the dipstick. | | |
#12705 05/11/2005 4:54 AM | | Anonymous Unregistered | | Anonymous Unregistered | just curious PAfarmer, does your splash oiler 235 also have the four bolts on the valvecover like the later full oil 235s? | | |
#12706 05/11/2005 3:07 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | The head #s are 8385913. block is a 3764476...235
I added 6 and now it right in the middle so Im happy now. That last quart went a long way.
So does this mean its not a "splash oil"? | | |
#12707 05/11/2005 4:13 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | The number of quarts always puzzled me. But as I wrote, my book says five (not counting a filter) and it shows full on my dipstick. I have a second 235 and it takes five and both dipsticks show full. What adds to my confusion is that the book says U.S. quarts but being up north we don't get quarts only litres. If I recall 5 quarts equates to 4.78 litres. On another note, if you buy a gallon of paint, you don't get a gallon. You get 3.78 litres. Paint cans are made in the USA to gallon sizes. Metric Madness!!! | | |
#12708 05/11/2005 4:20 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | I feel ya on the conversion madness we use lots of measurement units at work. I work for a company that was owned by Sweeds and they went by Mils. Germans bought us and they go my Microns. The machine shop I have stuff built at goes by millimeters, inches and thousandths.
Glad to see im not the only one with oil capacity confusion. My main reason I questioned the capacity is my dip stick looks like (well it has) been welded by an armature welder at the top portion where the blade connects to the handle. I was thinking maybe its to short. Maybe it’s a factory weld. | | |
#12709 05/14/2005 3:13 AM | Joined: Dec 2004 Posts: 20 New Guy | | New Guy Joined: Dec 2004 Posts: 20 | Articat53gmc, Just getting around to answering the question regarding my 235 splash oiler... The older 235's like mine have only two bolts right through the top of the valve cover just like the 216's. They also have the large side covers. My oil pan (big as you'd expect) has trays for each of the dippers to pick up the oil. PA Farmer | | |
#12710 05/14/2005 7:18 AM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | My 1960 shop manual says 5 quarts plus 1 more if you have a filter. | | |
