1 members (tesa), 142 guests, and 2 robots.
Topics128,080
Posts1,055,953
Members48,430
#1269189 06/16/2018 1:36 AM
Offline
I have a 1955 Chevrolet 3100 pickup. Can I use radial tubeless tires on the standard rims without using tubes. I think a made a big mistake. I wanted to keep the truck as original as possible, so I ordered 600X16 whitewall bias ply tires from Coker. The tires appear to out of round. The truck feels as though I am driving over a washboard road. Is it me, or has anyone else had problems with Coker????
442 #1269194 06/16/2018 1:58 AM
442,
I bought the same size tires, with the wide white walls as well. Only, I decided to go with a radial tire.I actually had to use tubes. My old rims just didn't want to hold a the bead from the tire. The tubes have worked out just fine. One of the challenges with a bias ply tire, is when the sit for a while, they develop a flat spot. It is should eventually, go away as you drive and your tire warms up. If it doesn't, I would contact Coker Tire. The communication that I have had with them has been outstanding. Hope this helps.
Rugo
Steve Rugg
53 3100
442 #1269196 06/16/2018 2:18 AM
Leo Offline
Moderator
Moderator
I tried airing up a tire without a tube in it, left it on the shop floor overnight, sure enough, it was flat the next day. I've been running tubes in all my radials for years now, no issues.
442 #1269199 06/16/2018 3:06 AM
The key to getting original rims to hold air is to:
-start with non-pitted rims (especially the tire bead area).
-sand blast them inside and out.
-epoxy primer.
-use epoxy on the rivet heads inside the rims.
442 #1269207 06/16/2018 5:57 AM
If your tires have been stored for an extended period in the vertical position, you may never be able to get the flat spot out. Always store bias ply tires laying flat on their sidewalls, not upright on the tread.
Re Coker Tire: I have gotten more than one set of defective tires from them, but they were excellent about replacing them.
If you do revert to radials, make sure to use a radial tube, specifically made for use in a radial tire.
1951 Chevy Panel Truck
MiraclePieCo #1269208 06/16/2018 6:20 AM
I disagree with this statement .
My experience was ,I bought some tyres that I knew had been stored for several years , stacked flat as above , they were on my truck less than 2 months and I noticed cracking between the treads , at the tyre shop , the first thing the shop owner said was "stacked flat!"
FAIL !
I had to buy new ones .
When I worked for the local airline , the dozens of tyres were all stored in racks , in the vertical position . The storage room was cool and dark .
442 #1269209 06/16/2018 6:27 AM
If you google "trouble with coker tires" there are several things there to read
eg
https://www.jalopyjournal.com/forum/threads/ever-have-trouble-with-coker-tires.877245/
442 #1269218 06/16/2018 11:33 AM
442, I can’t speak to Coker tires. But I do have many years of experence with bias tires, to help with flat spots try this. First , drive the truck more than a couple miles on a warm day on good road. Prehaps a trip of 10 miles or so. The issue may well disappear as the tires round out. If so, when you park it for the night try putting it up on jack stands (block it up or whatever method you have, not every night of course, just as a test since thay’ll stay round with no weight on them). This really helps when a bias tire vehicle sets for more than a few days in the winter.
Good Luck, RonR
RonR
1970 340 Duster
1964 CJ5
442 #1269220 06/16/2018 12:05 PM
Ex Hall Monitor
Ex Hall Monitor
I had the identical issue with Coker bias ply tires. Below is what I ran into. The image only shows the rear tires. I had the same problems with the front. Don't expect much out of Coker. They told me that's the way bias ply tires are by nature.
442 #1269223 06/16/2018 1:04 PM
back yard wrench turner
W Online: Content
Find a tire store that can true and balance your tires.
I had my bias ply tires trued and balanced. They rode very smoothly. I was quite pleased.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Dusty #1269250 06/16/2018 6:55 PM
FAIL !
I had the opposite experience: flat-spotted bias ply tires, had to have them shaved to make them round again. Tire store told me "Never store them upright or they'll flat spot."
So you had cracking from storing flat, I had flat spotting from storing upright. Bottom line evidently is that bias ply tires can't be stored very long in ANY DIRECTION or they will take a set.
442 #1269270 06/16/2018 11:42 PM
Turn them over once-a-year?
442 #1269282 06/17/2018 12:19 AM
Ex Hall Monitor
Ex Hall Monitor
My experience with bias tire flat spotting is the flat spot goes away after driving a few blocks. I've never had to have one shaved because of flat spotting due to storage.
Tiny #1269311 06/17/2018 5:13 AM
I've had a few sets of bias ply tires that were permanently flat spotted from sitting for ages with low air pressure and full weight of the car. Essentially ruined.
If you're not driving your car for months it's beneficial to get the tires off the ground, or move it forward and backward every few weeks.
442 #1269477 06/19/2018 12:13 AM
Some tire stores and warehouses have wooden, or metal racks that hold the tires vertical but support them with boards or planks that are canted at a 30-45 degree angle and contact the tire at approx. 4 and 8 o'clock.
Professional Novice
442 #1269493 06/19/2018 2:05 AM
...yep, got a good deal on a set of new tires and rims early in the restoration of my panel. Never thought much with just the chassis sitting on the tires (radials) and it sat a good while with the body/engine on them. The very day I was "finished" with it I drove it to the home coming in Md. and bounced there and back. tires flat sided so I just went ahead and put a new set on. No more bouncy, bouncy.
.....some magazines, years ago, said the first thing to do is put a set of tires/wheels on a resto to keep you motivated. Yeah right. That is the LAST thing I do...unless a great deal comes along!
Just my .02..........and yes, I have had tires seem flat and round out a little later when hot and a few miles at hot speeds.
442 #1269495 06/19/2018 2:10 AM
About 10 years ago I bought four 650-16 bias-ply Firestone/Coker tires. The compound must be different than it was way back because my tires do not flat spot even sitting in the garage for 5 months. They run smooth and I am very pleased with them. They do have that bias-ply wander at times.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
442 #1269525 06/19/2018 12:49 PM
I have had really good luck with my Coker STA transport highway tread tires. 650 by 16. They are 6 ply and run really smooth . Not like other bias I have not been happy with in the past, but this is a truck tire.
https://www.cokertire.com/650-16-sta-super-traction-6pr-5025.html
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
