9 members (Wayne67vert, DaveV, Phak1, Eisenholtz, Ponchogl, Bill Hanlon, 55shaker, Rusty Rod, TUTS 59), 159 guests, and 1 robot.
Topics128,049
Posts1,055,546
Members48,425
#126847 06/21/2007 1:53 PM
Apprentice
Apprentice
When installing my new Rockers on my 65 c-10 is it nessasary to remove the doors? Just want to know before I start.
#126848 06/22/2007 2:58 PM
No, I didn't when I installed mine. I actually found it helpful to have the doors on so that I could use them to line up the rockers before I welded them in.
Regards,
Steve
#126849 06/22/2007 4:42 PM
Both of mine needed work on the lower hinge pillar under the rocker so the doors had to come off.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#126850 06/24/2007 2:14 AM
Apprentice
Apprentice
Okay Thanks for the info.
#126851 06/24/2007 4:54 AM
For ease of access, it is better to have the doors off the truck. Before doing so, mark the hinge locations on the door jamb and the door with a scribe, to ensure proper alignment when re-hanging the doors, if you take them off. I found it a lot easier, however the do not have to be removed.
I do suggest using a spot weld cutter, for drilling the factory spot welds. I have done it several times and this is the best method and results.
Good luck with your project.
Tony
#126852 06/24/2007 6:18 AM
Would be a good idea to just spot weld in a few areas and then reinstall the door to check that the placement of the rocker is good before you finish welding it in place. It's a little more trouble that way, but much better than finding out later that the rocker needed to be moved a little to get it lined up right with the door.
Ralph Davis
1970 Chevy C10 Webshots
My Stovebolt Gallery page
Old trucks never die, they just find a new home.
#126853 06/24/2007 1:15 PM
I usually use zip-in 1/4" head sheetmetal screws to hold the rocker on, mount the door to check for fit. On the burb a coupla weeks ago I had to move one rocker end down about 1/8" or so. Sometimes you can get them to fit better than they did when new, mass production ya know. Then when you pull the screws just weld up the holes. I find an air drill w/a 3/8" or so bit is much faster than a spotweld cutter.
#126854 06/25/2007 1:29 AM
Apprentice
Apprentice
Thanks again Guy's for all the info,Well being a true Backyard Machanic and working on My truck in a field..I can't do any welding just yet untill I get my truck ready to drive {Don't want to catch the field afire!}especially since it's Not My field...
Anyway I put My new Patch panels on My front fenders and one Rocker panel..And I used Lord Fusor Bonding agent to secure them in leiu of Welding...Now I know what some of You will say about this method...I'll have them welded after I get it registered and am able to drive it..And Hey if it holds the Space Shuttle together {I figure its space age glue} It will hold My old Chevy together...Anyway I'll let You all know if My fenders or the Rockers fall off.
