| | | Forums66 Topics128,047 Posts1,055,532 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 38 Apprentice | | Apprentice Joined: Sep 2006 Posts: 38 | When installing my new Rockers on my 65 c-10 is it nessasary to remove the doors? Just want to know before I start. | | | | | Joined: Jan 2007 Posts: 93 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 93 | No, I didn't when I installed mine. I actually found it helpful to have the doors on so that I could use them to line up the rockers before I welded them in. Regards, Steve | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Both of mine needed work on the lower hinge pillar under the rocker so the doors had to come off. | | | | | Joined: Sep 2006 Posts: 38 Apprentice | | Apprentice Joined: Sep 2006 Posts: 38 | Okay Thanks for the info. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | For ease of access, it is better to have the doors off the truck. Before doing so, mark the hinge locations on the door jamb and the door with a scribe, to ensure proper alignment when re-hanging the doors, if you take them off. I found it a lot easier, however the do not have to be removed.
I do suggest using a spot weld cutter, for drilling the factory spot welds. I have done it several times and this is the best method and results.
Good luck with your project.
Tony | | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | Would be a good idea to just spot weld in a few areas and then reinstall the door to check that the placement of the rocker is good before you finish welding it in place. It's a little more trouble that way, but much better than finding out later that the rocker needed to be moved a little to get it lined up right with the door. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I usually use zip-in 1/4" head sheetmetal screws to hold the rocker on, mount the door to check for fit. On the burb a coupla weeks ago I had to move one rocker end down about 1/8" or so. Sometimes you can get them to fit better than they did when new, mass production ya know. Then when you pull the screws just weld up the holes. I find an air drill w/a 3/8" or so bit is much faster than a spotweld cutter. | | | | | Joined: Sep 2006 Posts: 38 Apprentice | | Apprentice Joined: Sep 2006 Posts: 38 | Thanks again Guy's for all the info,Well being a true Backyard Machanic and working on My truck in a field..I can't do any welding just yet untill I get my truck ready to drive {Don't want to catch the field afire!}especially since it's Not My field... Anyway I put My new Patch panels on My front fenders and one Rocker panel..And I used Lord Fusor Bonding agent to secure them in leiu of Welding...Now I know what some of You will say about this method...I'll have them welded after I get it registered and am able to drive it..And Hey if it holds the Space Shuttle together {I figure its space age glue} It will hold My old Chevy together...Anyway I'll let You all know if My fenders or the Rockers fall off. | | |
