6 members (Peggy M, Otto Skorzeny, Rusty Heaps, DadsFirstPickup, Hotrod Lincoln, klhansen), 132 guests, and 0 robots.
Topics128,043
Posts1,055,609
#1267118 05/26/2018 9:49 PM
I ordered new flywheel bolts for my 1959 261. They are 15/16" long versus the original bolts at 11/16" long. Will the extra length cause problems? Also, does it matter if I use Loctite blue or Permatex #2 on the threads?
Oldbolter
1959 Apache 3800 dually flat bed/dump with 261
1956 3800 dually flat bed/dump with 235
1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
3B Offline
Hy oldbolter, are you bolting on an automatic flex plate, a Hydramatic flywheel, or a standard transmission flywheel? The best check would be to assemble your parts and check fro interference somewhere, hope that helps.
If it’s a flywheel bolt your after, the correct bolt should be 7/16-20 X 1, gm 839756. Listed in my gm 59 parts catelog as 42-59 but that number was used for quite a few years, at least up through the early 80s. You can get real gm bolts and washers on eBay. Not all that expensive.
Mike
' Offline
Flywheel Bolts
GM # 0.669 - GM # 839756
PIC
https://s26.postimg.cc/c4317fqah/Bolts_Flywheel_GM_NOS.jpg
1954 3600
Now cruising in
The Passing Lane
Thanks for the help everyone. I'm bolting up a standard flywheel and it looks as thought the new bolts I ordered will be okay. I have no idea why the bolts I removed were so short. Thanks again for the help.
Oldbolter
It would probably be a good idea to run a thread chaser through the pressure plate to make sure the longer threads let you tighten the bolts down good.......just and thought.
