| | | Forums66 Topics128,035 Posts1,055,559 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 152 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 152 | I ordered new flywheel bolts for my 1959 261. They are 15/16" long versus the original bolts at 11/16" long. Will the extra length cause problems? Also, does it matter if I use Loctite blue or Permatex #2 on the threads?
Oldbolter 1959 Apache 3800 dually flat bed/dump with 261 1956 3800 dually flat bed/dump with 235 1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy oldbolter, are you bolting on an automatic flex plate, a Hydramatic flywheel, or a standard transmission flywheel? The best check would be to assemble your parts and check fro interference somewhere, hope that helps. | | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | If it’s a flywheel bolt your after, the correct bolt should be 7/16-20 X 1, gm 839756. Listed in my gm 59 parts catelog as 42-59 but that number was used for quite a few years, at least up through the early 80s. You can get real gm bolts and washers on eBay. Not all that expensive.
Mike
| | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | | | | | | Joined: Aug 2009 Posts: 152 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 152 | Thanks for the help everyone. I'm bolting up a standard flywheel and it looks as thought the new bolts I ordered will be okay. I have no idea why the bolts I removed were so short. Thanks again for the help.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | It would probably be a good idea to run a thread chaser through the pressure plate to make sure the longer threads let you tighten the bolts down good.......just and thought. | | |
