5 members (ShopRag, Phak1, Bill Hanlon, Otto Skorzeny, 3B), 116 guests, and 4 robots.
Topics128,034
Posts1,055,547
Members48,425
I'm about to install a Langdon HEI in my 55 235 that I bought a while ago. Anyone have any suggestions or tips for the install?
Any particular type of spark plug wire? I think he mentioned getting Ferd ones.
Any suggestions appreciated.
I think mine were for a F&%d...they have MITECH IGNITION Silver Series 8m/m written on them. Not much help but I really don't believe it matters.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
I bought the set up a few months ago and here is what mine are. My motor is a 235 1956 Chevy 3100 I do not know if you have this information or not but this is what he sent me.
(the ignition wire set that Tom sent me is General Cable Corporation #6064)
Spark plug wires Use 1980 300 Ford six spark plug wires or O’Reilly’s black wires #6064
(This is the distributor I purchased from Tom)
Distributor #’s Mini HEI 1110582 2D15, Vacuum advance 754 24. This unit is based on G.M. 2.8L “S” truck 1982-1984 and uses cap, coil, rotor, module, pick-up coil, and vacuum can from this distributor. The optional round coil is typical Ford electronic ignition 1977 to 1984
(I purchased these plugs from Tom)
Spark plug #’s Large gap for HEI gap .060 13/16” gasket style, Champion 66 RJ18YC6 Copper Plus
(Here is the instructions Tom sent me)
LANGDON'S STOVEBOLT MINI H.E.I. INSTALLATION
• Rotate engine to No. 1 cylinder firing.
• Set slightly before T.D.C. (approx. 100 180 B.T.D.C.)
• Remove your old distributor
• Install HEI distributor and assure full oil pump drive tang engagement.
• Rotate distributor until 6 points on internal star wheel line up with 6 points on stationary pole piece. Assure that the internal star wheel is near the top of the stationary pole piece not towards the bottom.
• Assure free play of HEI shaft by pulling up and down on rotor.
• Observe vertical location of internal star wheel relative to height of stationary pole piece. Star wheel should not be above points on pole piece.
• Note location of rotor and install #1 spark plug wire at this terminal. Install other wires in clockwise direction proceeding through the firing order (1-5-3-6-2-4)
• Use 1980 300 Ford six spark plug wires if you don't want to custom fit your own. The Ford wires fit but sometimes don't have identical boots on all spark plug ends. O’Reilly’s sells black wires with all boots identical (#6064).
• Power feed MUST be a #10 size wire direct from ignition switch to + terminal as shown (same side of coil as pink wire from distributor pigtail). Other terminal is for a tachometer and the tan wire from distributor pigtail. Delete any resistor - either ballast type or inline resistance wire, which was used on all 12 volt point style ignitions.
• It is okay to mount the coil further away from the distributor by extending the pigtail but be sure to solder all connections.
• Suggested spark plug type is the extended tip design, which is designated by a "Y" suffix on Champion brand or "S" suffix on an A.C. brand. (R44SX) The X designates a large gap on the A.C. brand. If using Champion brand, use RJ18YC6 or RJ12YC6.
• Suggested spark plug gap is .060" for improved idle & low speed driveability.
• Suggest transfer of timing mark to front of engine on the torsional damper so you can accurately adjust initial spark settings beyond the narrow window in the bell housing.
• Suggest initial timing of 100 - 180 (without vacuum advance connected)
• Suggest "ported" (above throttle blade) vacuum (to vacuum advance can) for mild cam engines. Suggest full vacuum for performance cam engines. Try both to see what your engine likes. If the engine likes something in-between, try combining both full and ported signals.
• For those wanting an original coil appearance, a round HEI coil (Ford HEI) is available from Stovebolt. Hook the pink wire to the coil + side (positive) and the tan wire to the coil - side (negative).
• This Unit is based on G.M. 2.8L "S" truck 1982-84 and uses cap, coil, rotor, module, pick-up coil, and vacuum can from this distributor. These parts are readily available at any auto parts store. Optional round coil is typical Ford electronic ignition 1977 to 1984
NOTE: Chevy 216, pre- 54 235's with steel cams and early GMC engines with steel cams will require a steel distributor gear to prevent excessive distributor gear wear. If you have one of the above engines please call us at 586-739-9601 for clarification before installing. Rev. 12 Apr 2012 bas
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen
56 Chevy 3100
Bring an old post back from the dead.
Been running a mini HEI from Tom for several years. had run the supplied Champion RJ18YC6 plug. Came time to replace them, I got a set of AC / Delco platinum #7, p/n 19360569 last year, runs great.
BC
1960 C60 pasture art
Good to know.
Just an FYI, that the ignition module for the GM 2.8's were problematic. Maybe replacement units are more reliable. The problem is not when running, but when you go to restart ignition would be dead. Let it sit for a short while to cool down and would fire right back up. Easy test with a multimeter if anyone ever runs into that.
1953 Canadian GMC 9314 w/ (factory) Chevy 235
