0 members (), 309 guests, and 4 robots.
Topics128,169
Posts1,057,102
Members48,463
Fixer of Things I Probably Broke
From another thread: anybody know what this is? [img]https://plus.google.com/102285877402416664124/posts/RbgRrx3LFXg[/img]
And any issues with grinding it down/off?
1953 Chevy 3100 Frankentruck with 235 and mostly original bits.
J M Offline
That looks to me like the steering stop on the front axle. There should be a bolt on the king pin that rests against it when the wheel is turned completely on one direction. The bolt can be adjusted to regulate how sharp you can turn the wheel.
Why do you want to grind it off?
Jim
It’s not a steering stop, that is bolted on with the lock pin for kingpin.
Likely result of the forging/manufacturing process. I don’t know that it has a purpose on the finished axle, but also no good reason to remove it.
•1952 Chevrolet 3800 pickup
---All pictures---
Originally Posted by Grigg
It’s not a steering stop, that is bolted on with the lock pin for kingpin. , but also no good reason to remove it.
The reason to remove it .............disk brake caliper hits this knob on full turn.
Can someone post a pic of the caliper hitting this part of the axle?
Just curious
Are you sure the steering stops are in place?
There is no reason a caliper should be anywhere near the center of the axle!
On full turn caliper hitting the knob. Caliper hits before the steering stop hits the spidle. It relatively slight and so far I have found the need to cut off the knob.
https://photos.app.goo.gl/bLHuykBSGGjozdnV6
https://plus.google.com/102285877402416664124/posts/cWW9PPzpoeWq1
https://plus.google.com/102285877402416664124/posts/ad1w6eu5n97
The other solution would be redrill the steering stop tab. If the new mounting hole was drilled at the stock locating pin making the effective length of the tab longer.
interesting...,
second pic didn't work for me
Or just weld a dab on the end... it's looking like only a cm of clearance needed. Though both do sacrifice turning radius (albeit slightly).
Wonder if that triangle knob was used as steering stop for other spindle configurations...
Dab of weld would work...........mine would need to be a BIG dab smile
Heres a pic of my P.O.L. Kit
...click...
...click...
I dont believe it was ever a issue
