8 members (KEVINSKI, mick53, 55shaker, Peggy M, Gdads51, Hanks custodian, MickeyP, 1 invisible),
148
Mod | | | Forums66 Topics128,089 Posts1,056,137 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | Hey everybody, What do you think my chances are of loosening one side of the windshield and replaceing the glass? The gasket is in good shape, I just need to replace the broken glass. Would I be better off removing the hole thing, and replaceing the gasket and the glass? I welcome any and all ideas, or suggestions. Jimmie D. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | i think , others may have more expierience , but i would remove the whole thing . reason 1 you will get a look under the seal for any creeping rust an fix it before it gets worse, Eastwoods encapsulater works great for this . reason 2 i dont think youll be bale to get the 1 pane of glass back in , the windshield was made to be installed as a unit . Just my thoughts | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | AW_Radial Thanks for your input. I had pretty much decided to replace the entire windshield. I can buy replacement glass for 28 bucks a pane locally so I think that is what I will do. | | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | i just had the windshield put in my 51 and the glass guy said they can do it but is not easy | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | If the gasket is more than a year old it will be to stiff to put back and not have it leak. Replace the gasket whenever you pull the glass.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | Hi Guys, Maybe I am doing something wrong, but it took me less than 30 minutes to remove the passenger side of the windshield. I used a fair amount of soapy water and 5 1 inch putty knives to loosen the rubber in increments from the pinchweld. The drivers side took even less time, with out cracking the glass. (at least anymore than it was) The local glass company cut a new piece using the old glass as a template. The cheapest place I could find for laminated glass online was 60 bucks. The local company did it for 28.50 plus put a rush on it so I could install it this weekend. 4onthefloor, you are right. I thought the gasket was good enough to reuse. After I removed it, it was obvious it needed replaced. So I will order a new gasket, and prep and paint the interior this weekend. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The thing is a lot easier to take out than put back in! I broke one side the first time I attempted one. If it feels like it is fighting you, then it is. Don't force it.
