1 members (klhansen),
98
0
Mod | | | Forums66 Topics128,126 Posts1,056,356 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 187 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 187 | I am at the stage of installing the original headlight buckets to the original fenders, along with new headlight retainer and bezel. I find the spring clip for hanging the bezel to the bucket very flimsy and not reliable. when attaching the only screw at the bottom it just lifts the bezel and the function of the clip is negated. Anyone come up with a solution so the bezel is more properly secured. This is not the best design for my liking, two screws placed say horizontally would have made for a more secure fit, any ideas would be appreciated
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | The spring clip goes into a slot at the top of the headlight bucket and the bezel snaps over the light. The screw secures the assembly. You do have the rubber ring that the clip holds to the bezel, correct? Properly assembled this seems secure to me. Kent | | | | | Joined: May 2015 Posts: 11,073 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,073 | Maybe the tab at the bottom that the screw fits into is bent outward too much, making the screw lift the bezel instead of drawing it mostly rearward. The original buckets on mine only have that tab bent slightly forward. Or maybe your new bezels aren't correct.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | Not only have I not had issue with the original setup, but I found that with a new rubber headlight bezel seal the bezel fits so snug I don't need the retainer screw at the bottom. In fact I had to apply dish soap to the bezel seal to get it to slide on to the headlight retainer. Sounds to me like something needs adjusted. | | |
