7 members (JW51, Gdads51, 52Carl, TrknGMC, Leo, texas46, 1 invisible), 193 guests, and 3 robots.
Topics128,101
Posts1,056,181
Members48,436
#1264042 04/29/2018 5:07 PM
I am at the stage of installing the original headlight buckets to the original fenders, along with new headlight retainer and bezel. I find the spring clip for hanging the bezel to the bucket very flimsy and not reliable. when attaching the only screw at the bottom it just lifts the bezel and the function of the clip is negated. Anyone come up with a solution so the bezel is more properly secured. This is not the best design for my liking, two screws placed say horizontally would have made for a more secure fit, any ideas would be appreciated
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody
The spring clip goes into a slot at the top of the headlight bucket and the bezel snaps over the light. The screw secures the assembly. You do have the rubber ring that the clip holds to the bezel, correct? Properly assembled this seems secure to me.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Maybe the tab at the bottom that the screw fits into is bent outward too much, making the screw lift the bezel instead of drawing it mostly rearward. The original buckets on mine only have that tab bent slightly forward.
Or maybe your new bezels aren't correct. ohwell
Not only have I not had issue with the original setup, but I found that with a new rubber headlight bezel seal the bezel fits so snug I don't need the retainer screw at the bottom. In fact I had to apply dish soap to the bezel seal to get it to slide on to the headlight retainer. Sounds to me like something needs adjusted.
