1 members (qside),
28
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 212 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 212 | The overdrive in my 58 started jumping out of high gear. It also has a singing sound at about 45 mph. I just took it out and put the original transmission back in.I Ordered an overhaul kit from southern gear. I hope it works for an overdrive. They only had a kit for a regular three speed. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Jumping out of 3rd gear is a common problem for regular 3 speeds and overdrive transmissions of that era. External causes can be from worn u-joints, worn front yoke, out of balance driveshaft, and sloppy shift linkage. Internal wear components consist of worn syncro rings/drum, 2/3 shift fork, collapsed spring ring on the clutch gear, worn rear bushing, worn bearings, and worn teeth on clutch gear. The OH kit for a regular 3 speed should consist of front & rear bearings, rear seal, needle bearings & thrust washers, rear bushing, and gaskets. It will not give you the rear bearing for the OD which is a number 6206. The OD gasket set is different, also you need the solenoid seal 3060 and OD shifter shaft seal 6130. Fred Note: Parts such as syncro's are getting hard to find and priced to match. You may wish to use the good parts from the regular 3 speed in the OD trans.
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Great answer Fred and good info. I have looked at a few 3sp trannys with the same issue and most had worn needle bearings in the clutch gear. Bad alignment of the clutch gear(input shaft) in the pilot bushing can cause the same. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
