| | | Forums66 Topics128,162 Posts1,056,932 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2016 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2016 Posts: 52 | Thinking about how to run throttle linkage. I have a 350 V8 with Edelbrock 600 carburetor in my 54 1/2 ton. I'd like to use the stock gas pedal or something that looks fairly stock. The cable pull pedals seem the most logical, but the only ones I'm finding online are big cast-aluminum race-car looking pedals. What did you do? | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 |
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2016 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2016 Posts: 52 | The original pedal is still in the truck. It looks like the 55.2 -59 linkage for the later model truck would be a very tight fit in my 54 with the engine so close to the firewall. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | OK then, use a cable throttle. Mod it to a stock pedal. Many V8 swaps in AD trucks here. They all have throttle. Someone will advise.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2005 Posts: 2,101 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,101 | I have used the aftermarket linkage on several 55-59 6cyl to V-8 conversions. It is tight on these trucks as well. I have not installed one with the engine in place however. Also, they have to be slightly modified as they come with a mount bracket for a flat firewall. The mounting location is not in a flat area. Typical aftermarket stuff. Fred
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I did not find an issue. The Classic truck Parts V8 throttle is an exact copy of original.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | Look at the LoKar throttle pedal set up that uses a bellcrank and cable on the engine side of the firewall. Normal sized pedal and allows positioning anywhere you like. Have installed two of them with years of trouble free service. | | | | | Joined: Apr 2016 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2016 Posts: 52 | I have ordered the Classic Parts 55-59 Throttle Assembly so now I am committed to make it work in my 54. Can anyone post a photo of one in a first series truck? | | |
