0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | I'm having a hard time installing new KYB gas adjust shocks on the front of a stock suspension 52 3100 series truck. The shocks came from LMC their part number 38-1686. THe old ones came off easy as they were shot. However these new ones which were compressed with the strap I can't compress enough even with a floor jack to slip in. What's the trick?
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I've had some hard ones in my day but none that hard. Generally I mount them at the top and then "push" up on them while laying flat of my back! The ones on my 52panel were tough but finally gave in.
.....do you have some "young'un" around that wants to show how stout he is? | | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | HI ALvin, I'm thinking now about putting a jack in between the frame and the axel and spreading it a little, maybe then it would go?
| | | | | Joined: Sep 2013 Posts: 1,364 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,364 |
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: May 2015 Posts: 11,070 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,070 | How about a bar clamp? Like the ones use for woodworking. That would compress the shock to where you could get the bolt installed. The way I've done shocks before is to cut the strap and stick the bolt in as it lines up the hole. But that's a one time shot, and if you miss you're in your situation. If the fenders are off, you might try bolting in the bottom of the shock and using your weight to compress the shock to insert the top stud in the bracket.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | This is what I ended up doing to get the front shocks installed. The front solid Axel is on jack stands with the tires off the ground couple of inches. I loosened up the bottom shock mount leaving it barely attached. Then installed the shock in the bottom mount. I then jacked up the frame just behind the front spring, which raised the frame up 3-4 inches. I then got a 2x4 about 15" long and aligning the top stud on the 2x4 pulled it down compressing the shock just enough to pop it over into the top mount and hole. These Gas Adjust KYB are a handful to get on the front. I purchased them from LMC their part number is 38-1686. However the real KYB part number is KB 4503 and can be purchased all day long from Jegs for $35.24@ vs what I paid. This procedure will work for 50-54 Chevy 1/2 ton trucks with solid axel and probably GMC also. I hope they don't make the truck ride like a lumber wagon.
