4 members (wilbur53, 2-Ton, 2 invisible), 63 guests, and 1 robot.
Topics128,076
Posts1,055,920
Members48,429
Hello all,
Installing a new fuel tank (Brothers Truck #ATK6062 Top Fill) in my '61 Apache 10. Placing it in the back between the frame rails, directly ahead of the rear bed crossmember. I had to make two plates to properly span the distance across. I thought it would be a good idea to add a rubber strip between the plate and the tank mounting tab on each side. A friend of mine thinks this is a mistake and should just bolt it up metal to metal. I figure engines are isolated from the frame by rubber mounts, cabs are isolated from the frame by rubber mounts, why not do this for the tank as well? I'd appreciate any insights you all have.
GW
"The duty of a patriot is to protect his country from its government." - Thomas Paine
Sir Searchalot
Sir Searchalot
Use rubber/fiber to keep straps/plates from rubbing a hole and anti rattle/squeak. How-to
If you can acquire some canvas type fire hose it makes excellent tank support strap padding- - - -lasts forever!
Most of the older cars with tanks with straps used a soft strip between the straps and tank and Ford used bolts with short stiff springs. Both approaches allow the frame some movement before transferring the twist or shift to the tank. Certainly won't hurt to add cushions but I would use a keyed or self locking nut in case pad compresses or disintegrates.
Evan
3B Offline
Hy Greenman Wood, if your tank is going to contain a fuel gauge sending unit and you are going to isolate the tank from the frame with some kind of non-conductive material, then you must add a ground wire from one of the sending unit mounting screws to the vehicle chassis so that there is a circuit connection to the fuel tank, hope that helps.
Thanks to all.
3B - the bolts that hold the tank touch the tank mounting tabs on one side, pass through the rubber strips and then attach to the frame on the other side. That should give the ground I need, but you can never have too many grounds! I'll run one as you suggest.
GW
I second Jerry's idea about some old fire hose pieces. I used them on the bottom of my wooden support blocks on my panel and they work really well. They have layers of rubber and a polyester that will never rot. Go by an firehouse as they usually have some old discarded hose laying around.....mostly the out lying volunteer ones are the best. I've kept a good size length laying around for years. (sorry used the last on the panel)
