4 members (Steelonsteel, FishinToms53, Gdads51, 1 invisible), 126 guests, and 3 robots.
Topics128,045
Posts1,055,528
Members48,424
#1262010 04/09/2018 8:47 PM
Fixer of Things I Probably Broke
I've got an auto choke Rochester BC that is currently set up for manual choke -- because... FUN!
However, the auto-choke vacuum port just keeps sucking in outside air. Is it fine to just cap this off hard? Or is the carb relying on that extra air intake for something besides heating the spring? (Ie, do I need to slap a filter on it).
1953 Chevy 3100 Frankentruck with 235 and mostly original bits.
"cap it off hard"
If you have a 53/54 (or, earlier) BC, that choke uses a heat stove that is clamped to a manifold. It relies on heat transfer to actuate the choke flapper and it is "balanced" by engine vacuum. It literally sounds like you have a vacuum leak?
I'd "cap it off hard" - plug that leak.
Let's see what others have to say?
http://chevy.oldcarmanualproject.com/carb/Rochester/9C304p02.htm
http://chevy.oldcarmanualproject.com/carb/Rochester/9D8p07.htm
It's already ruined with the manual choke conversion. Go ahead and plug the port- - - -it won't make things any worse.
cant get a temp indication on the gage. How can I check the sender to see if its working?
The only way to test the sender is to apply heat to it (run the engine for a while). If the gauge doesn't move when the sender is heated up, you either have a bad capillary tube/bulb or a bad gauge. Either way, you need another gauge/sender assembly.
