1 members (stlcardinalsguy),
71
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | Hi Guys,Gals...I want to start sanding on my truck. What is the first step,grit? Good Primer,and can you describe to me the wet sanding proceedure. Thanks MIke G...also..how do I know when to prime? (if I have Sanded good enough)
HURRY UP AND WAIT 55 235 3/4
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Some broad questions there, do a search here for "basics of basics" by Martin Snr or "Brian Martin". First thing I would say is wash it w/hot water & Dawn, scrub it real good. If yu have mutiple coats of paint, you prolly need to strip it down to metal using 80 grit. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | You should use a grease and wax remover before you start sanding. If you don't, you will imbed it into the paint and metal. | | | | | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | I think the last time my truck was polished was 1955..most of the paint is gone and i have some redish primer showing thru..I think its still on the origanal paint. If I start with 80 grit...do I graduate to a finer sand paper..or do i skim a bondo coat over what I have sanded and then sand with fine? Or do I sand down to metal and then prime,and then skim a coat of bondo? Or should I just find that website you mentioned/ M.G
| | | | | Joined: May 2007 Posts: 275 Shop Shark | | Shop Shark Joined: May 2007 Posts: 275 | DA sand it with 80 grit to get to the bare metal. Then use 180 to take out all the 80 grit scratches. Start with one fender, get it sanded to metal then get two coats of Epoxy Primer on it before surface rust starts.
Then start the next item. Again as soon as you get it stripped, get some Epoxy Primer on it.
After you get everything stripped and epoxied, you can start with the body work. You can apply the "bondo" right on top of the epoxy primer.
Again work one panel at a time. One door, one fender, hood and etc. After you get a panel worked and you're satisfied with the look, spray a coat or two of Epoxy Primer/sealer on it. You don't have to sand the Epoxy Primer/sealer when you go to apply your base coat.
What kind of paint are you planning to use. Base Coat/Clear Coat (BC/CC) or Single Stage (SS).
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now. http://www.coxcustomcars.com/ | | | | | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | Countilaw...Thanks, Now my base coat is the actual color..Correct...and then the clear will be top coat..Bare with me, all i am doing is getting expert advice since this is my first project...and i really appreciate the help.My origanal color is Juniper Green, with white bumpers ..ect...and that is what I am going to use for colors.Please send me more info, Thank you M/G
| | | | | Joined: Jun 2005 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 128 | | | | | | Joined: May 2006 Posts: 256 Member | | Member Joined: May 2006 Posts: 256 | Ha Ha Ha..awsome bent..I read in one of these forums that someone said the first thing to do is get a tetnous shot (spelling)..But I did substitude beer for that...Also..thanks for the link Jo Michael, and everyone else that has got me started. Just think..about 2 years ago, I used to put my car in the shop to change the oil...This Yankee has come a long way...M/G
