1 members (Hotrod Lincoln),
60
0
Mod | | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | The counterweight on my heat riser valve somehow went missing. The shaft is still in place but both the spring and the counterweight are now gone. I see that the shaft is sold by some of the vendors but does anyone know how you can find the weight? Do I have to go to a salvage yard for this? Thanks.
1956 Chevy 3200
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | First thing I'd do is post an ad in the swap meet Parts Wanted Forum. Someone may have a broken or cracked manifold laying in the back of the shop? The counter weights I have seen are held on by a roll pin so if you find one on a scrap motor tap out the roll pin if the shaft is the same size. I think the roll pin is 5/32 but not sure. | | | | | Joined: Oct 2014 Posts: 94 Shop Shark | | Shop Shark Joined: Oct 2014 Posts: 94 | Joe, ?? maybe an "old school" salvage yard, but I would say ebay or (as Chipmunk said) swap meets/Parts wanted forums would be your best bet.
I needed a Oil filler/Breather Cap, went to 4 junkyards/used parts/Pull-a-Part yard with no luck. Not worth the hassle, bought one from Classic Parts, Kansas City for $3.95
I have the Manifold that came with my Core engine....I did look for you, but the Counterweight was missing.
Good luck, Jim | | | | | Joined: Feb 2004 Posts: 29,767 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,767 | It wouldn't be that difficult to make a counterweight- - - - -just do a little tinkering with the offset to give it the right amount of leverage. I'd use something like a piece of 3/4" steel square stock with a hole drilled in one end and a slot for a pinch bolt to clamp it to the shaft. Most of the resto-ripoff sites sell the spring. Jerry
| | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Joe,
Original exhaust manifolds are an example of what street rod builders throw away. With some sniffing around you should be able to find that part for just the cost of postage, While the manifold is off might be the time to make the shaft and some bushings for the manifold from stainless steel. I did that on my '36 Chevy PU about 35 years ago and it totally cured the sticking shaft problem.
Ray
| | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | Thanks, everyone, for the responses. I will post an ad in the Parts Wanted section and also probably tinker with fabricating a weight as Hotrod Lincoln suggests.
Joe
1956 Chevy 3200
| | | | | Joined: Aug 2017 Posts: 660 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 660 | Are the 216 & 235 the same size heat risers?
1950 Chevy 3100
| | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | Good question. I'm not sure. I think there is mention of this in the service manual. I'll check it out.
A question for Ray: When you made your stainless heat riser shaft, what did you use to cut the slot where the spring hooks up?
1956 Chevy 3200
| | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | Per the service manual: "the exhaust manifolds on the 216 and the 235 are interchangeable."
1956 Chevy 3200
| | | | | Joined: Aug 2017 Posts: 660 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 660 | I might have one for you. Have to dig it out of my parts shed. Check your PM for message//// Todd
1950 Chevy 3100
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Use email or Private Message for person-to-person communication?
Joe has no email listed, but he is accepting PMs. | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | "A question for Ray: When you made your stainless heat riser shaft, what did you use to cut the slot where the spring hooks up?"
Joe,
I wish I could remember but that was about 35 years ago and my 73 year old brain is not so reliable any more on details like that. I may have used a slitting saw and my milling machine but a hand held hacksaw could do the job well also.
The stainless steel shaft and manifold bushings cured a chronic sticking problem that I and others were having and no amount of heat riser lube permanently cured it. In any event, in 35 or so years the sticking problem has never returned so it's definitely "problem solved". Others on this forum suggest a hammer as the proper tool to free stuck hear riser valves but I prefer finesse to brutality and I can enthusiastically recommend the stainless parts. If stainless round bars are not readily available to you the parts can be made from hardware store stainless bolts.
If you have any other questions give a shout.
Ray
