5 members (Wayne67vert, Otto Skorzeny, dt235sd, Cosmo, Hanks custodian), 85 guests, and 2 robots.
Topics128,059
Posts1,055,825
#125922 05/02/2007 9:22 PM
V
V Offline
Hey all,
Is it possible to disassemble the bed on my 59 fleetside by simply unbolting the front section, tailgate trunions and chain mounts, and support rails? Or are there welded sections to contend with? I'm trying to find the best attack plan for stripping/painting.
Thanks!
1959 3200 Apache Fleetside
In the Legacy Gallery
V
V Offline
Well somebody must have taken apart a fleetside bed before...
If it is like the 60-66(many of the parts are the same), the only welds are at the bottom corners, rear cross sill to the bedside, all mine have had two small welds there on each side.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
vtapache:
Ditto what Brian said on the '60-'66 fleetside beds. In addition to the small stitch welds on the rear cross sill, there are a few bolts with capture nuts, therefore the rear cross sill can be reassembled via the bolted connections. Good luck with your project.
Tony
