| | | Forums66 Topics128,043 Posts1,055,612 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2002 Posts: 96 'Bolter | | 'Bolter Joined: Oct 2002 Posts: 96 | Hey all, Is it possible to disassemble the bed on my 59 fleetside by simply unbolting the front section, tailgate trunions and chain mounts, and support rails? Or are there welded sections to contend with? I'm trying to find the best attack plan for stripping/painting. Thanks! | | | | | Joined: Oct 2002 Posts: 96 'Bolter | | 'Bolter Joined: Oct 2002 Posts: 96 | Well somebody must have taken apart a fleetside bed before... | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | If it is like the 60-66(many of the parts are the same), the only welds are at the bottom corners, rear cross sill to the bedside, all mine have had two small welds there on each side. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | vtapache:
Ditto what Brian said on the '60-'66 fleetside beds. In addition to the small stitch welds on the rear cross sill, there are a few bolts with capture nuts, therefore the rear cross sill can be reassembled via the bolted connections. Good luck with your project.
Tony | | |
