| | | Forums66 Topics128,107 Posts1,056,221 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 76 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 76 | I did a search for Auxiliary Brake Fluid Reservoir but I was unable to find out anything. What is this called? See attached photo. Thanks! Harmon [img] http://www.atlantamafia.com/Img_7665_small.jpg[/img] | | | | | Joined: Jul 2000 Posts: 2,193 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,193 | Try Googling remote reservoir. Like this?
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Feb 2004 Posts: 29,802 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,802 | Good grief- - - -a hundred bucks for something that can be made with a piece of copper tubing soldered into the bottom of a brake fluid can? Jerry
| | | | | Joined: Mar 2017 Posts: 76 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 76 | I guess I didn’t ask the question properly. I hope to reuse this one. I just wanted to know what it was called in case I could not and needed to find one. I was searching this forum as it is on my 40 Chevy truck. It’s nothing no more than a reservoir.
Would this have been a GM part or an add on from Railway Express Agency?
Harmon
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Harmon, anytime you post asking questions PLEASE post year and model of your truck, ie; 1954 4100 235ci. We’re good but not that good. I see you said it’s a ‘40 but what size? So, help us help you. ðŸ›
| | | | | Joined: Mar 2017 Posts: 76 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 76 | I didn’t mean to confuse. It is a 1940 1 1/2 Ton Chevrolet with a Ward box body. The brake reservoir is mounted on the firewall and runs down to the master cylinder. The engine is s 216 with a four speed and closed driveline. I imagine this reservoir assisted in extra braking power back in the day. I hope to reuse as much as possible of the parts where I can of a very rough but unusual truck.
I posted photos of the truck on big bolts and Jerry has been a huge resource of information on the engine and transmission.
Does anyone have this reservoir on their trucks?
Thanks!
Harmon
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | The reservoir has nothing to do with the power of the brakes, it only supplies sufficient fluid. Additional power can be supplied, if wanted, by the addition of a hydrovac(vacuum) booster; or revised pedal geometry.
Ed
| | | | | Joined: Feb 2004 Posts: 29,802 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,802 | With the custom body, the conventional method of filling the master cylinder was probably difficult or impossible to do. The remote reservoir did nothing to improve the performance of the brakes- - - - it just made topping off the fluid more convenient. Jerry
| | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | I would like to add one to mine just to ease the checking and filling procedure, and to eliminate the original "open to atmosphere" cap vent arrangement (the hole in the cap).
| | | | | Joined: Mar 2017 Posts: 76 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 76 | Thank you for the information. That makes sense. The area under floor is rotted so I don’t see the typical access plug.
Harmon | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | That is an interesting component for the reservoir. I wish other models used something similar as checking brake fluid levels is rather a pain in the neck. Would you mind taking a picture of the master cylinder fill plug where this reservoir line attaches? | | | | | Joined: Mar 2017 Posts: 76 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 76 | That is an interesting component for the reservoir. I wish other models used something similar as checking brake fluid levels is rather a pain in the neck. Would you mind taking a picture of the master cylinder fill plug where this reservoir line attaches? Paul, I would be glad to. I am outside of Atlanta and the truck is on our farm in SC. I have some pressure washing to do on the truck. It will be a few weeks but will take a few photos to see where this one attaches. Harmon | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I am helping restore a Railway express truck that has a remote fluid reservoir like that. I haven't put it back on yet but have it all cleaned up & painted. Like they said its there for a convienant way to service the MC. This one is a early 50,s Ford.
George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2017 Posts: 76 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 76 | This one is rough. I have an entire driveline and engine now. I need three more wheels. I am collecting along for now. For now being under cover and cleaned out is a huge start. Best to you on the restoration.
Harmon | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | This one is rough. I have an entire driveline and engine now. I need three more wheels. I am collecting along for now. For now being under cover and cleaned out is a huge start. Best to you on the restoration.
Harmon Harmon, I may have a lead on some rims at a junkyard in/near Commerce, GA. Are yours the ten lug hub centric style? Shoot me a PM and we can compare notes. Paul | | | | | Joined: Mar 2017 Posts: 76 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 76 | Thanks Paul. I sent a PM
Harmon | | |
