| | | Forums66 Topics128,111 Posts1,056,258 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#12585 06/11/2002 1:26 AM | Joined: Jun 2002 Posts: 21 Member | | Member Joined: Jun 2002 Posts: 21 | I am looking to change rear ends and go to an open drive line. I want to keep the 6 hole wheels that are original. When did the spacing for the 6 hole wheels change in GM trucks? Also someone mentioned a blazer rear end as a normal doner. Do the blazer axles have the same stud spacing? | | |
#12586 06/12/2002 10:28 PM | Joined: May 2002 Posts: 20 Member | | Member Joined: May 2002 Posts: 20 | I know that 6 lug wheels from a 86 6 lug 4x4 Chevy fit on my 49 truck.
Porky Pig is just a ham.
#12587 06/13/2002 5:49 AM | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | tires of the back of my brothers 46 half ton fit right on a 90's half ton 4x4 chevy suburben | | |
#12588 06/17/2002 9:54 AM | Joined: Jun 2001 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2001 Posts: 85 | For the most part, K/5 components are regular old GM stuff. I have a '68 C/10 stepside, a '67 K/10 Sub, a '71 GMC Jimmy and just got a '72 Chevy blazer rolling frame. All the 12-bolt pumpkins were the same.Might be some 2whl/4whl differences in spring perches, coil vs leaf?
Every 25 years I like to rebuild that 292 just for GP
#12589 06/21/2002 2:38 PM | Joined: Jan 2000 Posts: 101 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 101 | I am putting a 3.42 mid 80's K-5 Blazer rearend in my 46 for the original wheels.
Mark
1946 1/2 ton - 1962 "261" 1953 1/2 ton 5-window - "235" 1955 1/2 ton - 55 "265" Corvette motor 1959 1/2 ton Fleetside - "283"
