3 members (2-Ton, carbking, Guitplayer), 291 guests, and 0 robots.
Topics128,089
Posts1,056,141
Members48,436
I am looking to change rear ends and go to an open drive line. I want to keep the 6 hole wheels that are original. When did the spacing for the 6 hole wheels change in GM trucks? Also someone mentioned a blazer rear end as a normal doner. Do the blazer axles have the same stud spacing?
I know that 6 lug wheels from a 86 6 lug 4x4 Chevy fit on my 49 truck.
Porky Pig is just a ham.
tires of the back of my brothers 46 half ton
fit right on a 90's half ton 4x4 chevy suburben
Luke Dahlin
1946 Chevy 2 ton
1966 Chevy 2 ton
1969 Chevy 3/4 ton 4wd
http://www.stovebolt.com/gallery/dahlin_luke_1969.html]1969 Chevy 3/4 ton 4x4
For the most part, K/5 components are regular old GM stuff. I have a '68 C/10 stepside, a '67 K/10 Sub, a '71 GMC Jimmy and just got a '72 Chevy blazer rolling frame. All the 12-bolt pumpkins were the same.Might be some 2whl/4whl differences in spring perches, coil vs leaf?
Every 25 years I like to rebuild that 292 just for GP
I am putting a 3.42 mid 80's K-5 Blazer rearend in my 46 for the original wheels.
Mark
1946 1/2 ton - 1962 "261"
1953 1/2 ton 5-window - "235"
1955 1/2 ton - 55 "265" Corvette motor
1959 1/2 ton Fleetside - "283"
