4 members (Hotrod Lincoln, Guitplayer, LAROKE, 1 invisible), 54 guests, and 3 robots.
Topics128,154
Posts1,056,840
Members48,456
-db
Offline
- Offline
I have a set of wheels for a different car that I need to sandblast. The lip is chromed and the center is powder coated.
What media can I use to strip both with doing the least amount of pitting to the aluminum? I plan to paint the centers then give the lip a brushed look then clear them.
A friend of mine owns a blasting business. He say's nothing will touch the powder coating. ohwell
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
Check with Eastwood, there was something in the last catalog that would "disolve" powder coating.
http://www.eastwoodco.com/jump.jsp?itemID=16496&itemType=PRODUCT
Lee
1965 Chevy C-10 Gallery page
My Chevy truck pages more info and pictures!
1961 Studebaker Hawk
1962 Shasta 16' AirFlyte Travel Trailer
1941 Case Model S tractor
-db
Offline
- Offline
Wow, I can't believe that powder coating is that hard.
That Eastwood stuff is really expensive. I would have to probably buy a couple gallons of it to fill something enough to cover the wheel 1/2 way.
Looks like I may not be messing with it then. May just end up living with them through another set of tires then replace them.
Why not buy a quart, put the wheel in a tub, use a paintbrush to keep the powder coat wet for a few minutes and you're done. I think the stuff just needs to stay wet to work, you don't have to submerge your parts.
You could always ask the powder coating people what they use... I've seen parts coated the wrong color and they were redone.
Lee
-db
Offline
- Offline
Lee - I was thinking about that also, but they are 15" wheels.
I went to a local media blasting place today and the guy was very informative. Not to mention the DIY shop rates seemed really cheap. If you use one of the cabinets it's $12.50/hr and if you need the blasting booth it's $17.50/hr. If you pay them to do the blasting, it's $45/hr.
Anyway, he said you can blast off the powdercoating. It just may take you an hour per wheel to do it depending on the quality of the powder job.
If anyone is in SW-MI check out http://www.consolidatedstripping.com/
Just a tip Gents remeber WE use tape to protect an area ya DO NOT WANT TO BLAST , well powder coat is kinda like that the sand will bounce off instead of cutting through it , wich is why it is such a B%&^# to get off , but if you are persistant an spend the time you will burn through it eventually , BEEN THERE DONE THAT..LOL !
1952 Chevy Shortbed
Photos in Photobucket
