2 members (Rusty Heaps, panic),
51
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2017 Posts: 370 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 370 | I have a 216 cid with a sm420 transmission in a 3600.
Is it best to down shift when coming to a stop or slide up in neutral? What are the pros and cons?
Don
Can’t begin to tell you how much I hate the name Stovebolt.
| | | | | Joined: Dec 2015 Posts: 2,062 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,062 | I sometimes do both together or one or the other. Defensive driving says get your foot on the brake pedal so your brake lights are on early so those behind you are alerted that you are stopping. Also, if you are going to wear one of them out, the brakes are easier to change out than the clutch! | | | | | Joined: Sep 2017 Posts: 135 Shop Shark | | Shop Shark Joined: Sep 2017 Posts: 135 | Why would there necessarily be pro's and cons? It would just seem to be preferences. Sometimes I do one, then do the other. You would save a little on brake shoe wear, or wear a little on engine clutch and transmission. Brakes could fail during a stop, and you could just let out the clutch in a lower gear. I have had that happen. Just as often as having a clutch fail and drive home without one.Had that happen twice.
| | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I don't shift down just to reduce wear on my brakes. Approaching a red light, I only shift down into my 2nd (SM420's 3rd) if I feel the light is going to change in my favor before I get there. Otherwise, it's all brakes.
At a stop sign, I'll shift into my 2nd if the coast is clear and I'm not going to stop. Just trying to keep my carbon footprint down, right? 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Jun 2005 Posts: 1,001 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,001 | Also, if you are going to wear one of them out, the brakes are easier to change out than the clutch! x2
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Jul 2000 Posts: 2,187 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,187 | Downshift, apply brakes while putting your lips together and blowing out making a "brup, brup, bruppppppppp" noise to simulate jake brakes.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Sep 2017 Posts: 135 Shop Shark | | Shop Shark Joined: Sep 2017 Posts: 135 | At a stop sign, I'll shift into my 2nd if the coast is clear and I'm not going to stop. Just trying to keep my carbon footprint down, right? I didn't want to admit that on my part...LOL | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Had a buddy once who down shifted all the time....and from some pretty high speeds. I could just see the crankshaft torqueing up and down on the ends!.....while the engine begged for some relief. Engine puked and I just told him "told you so". Yeah, for me no down shifting except in an emergency. Just my opinion. | | | | | Joined: Jan 2001 Posts: 1,419 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,419 | What's cheaper, brakes or a transmission? When I started driving this question was posed to me and I've driven accordingly ever since.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Sep 2017 Posts: 135 Shop Shark | | Shop Shark Joined: Sep 2017 Posts: 135 | Sounds like some people really have no clue as to how and when to down shift, it is not an exercise in destruction. There should be no wear on engine or transmission to speak of. That's why I don't let many drive my vehicles. | | | | | Joined: Jan 2001 Posts: 1,419 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,419 | Sounds like some people really have no clue as to how and when to down shift, it is not an exercise in destruction. There should be no wear on engine or transmission to speak of. That's why I don't let many drive my vehicles. Why would there necessarily be pro's and cons? It would just seem to be preferences. Sometimes I do one, then do the other. You would save a little on brake shoe wear, or wear a little on engine clutch and transmission. Brakes could fail during a stop, and you could just let out the clutch in a lower gear. I have had that happen. Just as often as having a clutch fail and drive home without one.Had that happen twice. Pretty much how I do it. Only had 1 clutch in over 110k miles, broke a 2nd gear out of the blue. I have had two 3sp+od transmissions so, being sixty to seventy yo I take great care.
| | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | You up shift a manual trans to bring the engine rpms down. Slowing down, down shift a manual trans when or just before the engine starts lugging in the gear you're in. Disengage the clutch when coming to a complete stop. Lot of variables, such as turning corners at low speeds, non-synchronized first gear, etc. If you haven't learned how not to ride the clutch or brakes when driving you need an automatic trans vehicle. Very few people actually know how to drive a manual trans vehicle these days. I dislike it when stopped on a hill and the person behind you is on your rear, giving you anxious moments doing the clutch/brake/gas shuffle when taking off.
Rick
1939 Chevrolet Stake Truck
| | | | | Joined: Dec 2013 Posts: 771 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 771 | Just for fun and the sake of this discussion. Scroll down the page after opening the link........ GEARSHIFTING | | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | Just for fun and the sake of this discussion. Scroll down the page after opening the link........ GEARSHIFTINGInteresting that the "Shifting To Lower Gears" instructions DO NOT mention downshifting for the purpose of braking or decelerating. Add me to those who choose which technique to use depending on which component is least expensive. Every gear engagement puts microscopic wear on synchos, gear teeth, u-joints, etc. Brakes are cheap and disposable. Just don't coast up to stop signs in neutral when taking your DMV road test; they claim that's "out of control."
1951 Chevy Panel Truck
| | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | I have always looked at downshifting to slow down as just normal driving. I just take my foot off the gas, let the engine slow things down, brake and downshift at the same time. If your brakes go out, you can down shift to the point of almost a dead stop using the engine, an stoop the truck with the e-brake.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Sep 2017 Posts: 135 Shop Shark | | Shop Shark Joined: Sep 2017 Posts: 135 | That was kind of interesting reading for what it was, a short primer for tyro's on driving. But its on the same scale as saying that the story of Jack and Jill accurately describes how to be a mountain climber. If you don't have time/inclination to learn how your standard should be driven, by all means stay on the safe side and don't break it. Nothing worse than putting a lot of work into a classic and then tearing the trany or clutch out of it. But repeating myself, "That's why I don't let many drive my vehicles." | | | | | Joined: Jan 2001 Posts: 1,419 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,419 | I have only let a handful of people drive my truck as well. The question begs, "Where do you learn to drive a standard?" Family friend or Dad who might have bad habits, self-taught, armed with "Don't ride the clutch" ? Lee, with all your experience being a mechanic you've seen the worst of the worst abuses of drivetrain and brakes of that I am sure.
I have never abused a car or truck in my life, consider them transportation and with good care and preventive maintenance carefree miles can be had. I remember as a young buck helping a neighbor change out rear axle seals, I said to myself right there that seeing the differential for the first time it made no sense to 'peel out' like the local teens openly wondering if they had ever seen the inside of a differential or transmission.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I have "geared down" a few days in my lifetime for safety. Save the engine, save the brakes.....and save ME. But no down shifting in everyday life.
For those who may not know.....you can drive a car hard, and fast, without killing it. Its an art many don't learn unless they learn the hard way! Read below.......
Cosmo, I agree with you. Back in my mid teens to mid 20's I learned a valuable lesson. Out of aggravation I hit the windshield with my fist and broke it, scattered a clutch and pressure plate unnecessarily, crumpled a back bumper out of anger, and countless transmissions and rear ends.......THEN one day I figured out who was paying for it. Just about every weekend my buddies were under their cars, or under the hood while I hardly ever raised the hood on mine. When they ask me why, I ask them why they thought they had to do a jack rabbit start or spin the tires at every ice cream and burger joint!
This is just a funny note...hopefully not to far off thread. Today my nephew and his 25 year old son, brought my 50 coupe home to me. Brandon has had trail bikes, 4 wheeler, and messed with race cars as well as drive 5 speed shifts..........but today, when he got in the car to back it off the trailer we had a good laugh. He wanted to know how to put it in reverse....it has a 3 on the column shift. I laughed till I hurt watching him figuring it out! Young folks...hehehe , but didn't we all have to learn somewhere?!
| | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | Yep, I learned on my buddy's fathers 1960 Valiant. It had a 3 on the tree, slant six. I have never had to change a clutch on my vehicles. I've put well over 100,000 miles on my manual transmission trucks. Never had to replace the clutch on any of my tractors either. I rebuilt the 3-speed, floor shift trans in my 1939 Chevy 3/4 ton stake truck last fall because of bearing noise and vibration. While I was at it, I replaced the throwout bearing, pilot bearing, clutch and pressure plate. It still had the original clutch/pressure plate. It wasn't wore out, but was getting close to the rivets. I get lots of miles on brakes too, can't say the same for the vehicles the wife drives. I enjoyed my vehicles with the 3 on the tree, more so than the floor shift vehicles. As I've gotten older there is a lot to be desired with the automatic transmission.
Rick
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I don't understand the debate. The OP asked about what folks do when they pull up to a stop, shift to first before you stop or after, at least that's how I read it. I shift to first after I stop. When sitting at a light I shift to neutral to save the throwout bearing.
| | | | | Joined: Nov 2004 Posts: 2,399 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,399 | I was taught to downshift by my Dad in the '70s. It's never caused any problems for me.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | |
