2 members (49 panel, Hotrod Lincoln), 42 guests, and 3 robots.
Topics128,030
Posts1,055,428
Members48,422
#1257085 03/02/2018 1:54 PM
Hi folks,
Could some of you kind folks tell me what sort/type of headers/manifolds these are and point me in the direction of a good replacement that does't look so bad.
[img]http://s1060.photobucket.com/user/stooby69/media/20180227_120005_zpsk1q7h2ye.jpg.html?sort=3&o=0[/img]
[img]http://s1060.photobucket.com/user/stooby69/media/20180227_115936_zpsko3c6qdw.jpg.html[/img]
Stooby #1257088 03/02/2018 2:10 PM
they are called Rams Horns and are pretty desirable for the guys putting V8s in place of I-6s in the early Stovebolts. Helps with steering box clearance. ohwell
Stooby #1257093 03/02/2018 2:43 PM
Many factory versions, many replicas available.
Stooby #1257094 03/02/2018 2:49 PM
H Online: Content
Ram's horns create steering box problems- - - -they don't help with the conversion. The manifolds that offer steering box clearance benefits are the ones for 55-57 passenger car 265 engines with the driver's side exhaust pipe flange between the front pair of cylinders. They're on Ebay pretty regularly at bargain prices. Rams' horns offer better breathing at high RPM, but it's a moot point for street-driven engines unless you just love paying speeding tickets.
Stooby #1257190 03/03/2018 12:53 AM
I run the ramhorns on my '62 C10 with a 327 V8.
Original engine in the '62 C10 was a 235 I6, but there was an option for the 283 V8, so the SBC is an easy conversion.
Stooby #1257197 03/03/2018 1:31 AM
Stooby, if I understand it correctly your working on a 56 pickup. They were available with the early V8's (265) and I believe you have room to run a set of ram horns but I could be wrong.....there was a lot of room under their. My buddys and I stuffed a 427 into a 56 back in the 60's but I just don't remember the set up that well now.
Stooby #1257203 03/03/2018 2:18 AM
Riding in the Passing Lane
Those manifolds look good it they are blasted & painted with a high heat manifold paint.
George
1972 Chevy c10 Cheyenne Super
Stooby #1257207 03/03/2018 2:35 AM
I use the 1500° Flameproof paint I get at O'Rielly's. It has a ceramic component to it and performs well at regular exhaust temps. I forget who makes it. I'll double check when I get back home tonight.
Stooby #1257228 03/03/2018 6:41 AM
Here's the paint I use.
VHT Flame Proof Header Paint. I get it at O'Rielly's.
62Stick #1257232 03/03/2018 11:06 AM
I'll have a look and see whats available in the UK
