2 members (ShopRag, DaveV),
97
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | What is a decent battery to buy.I want to spend no more than $150. 58gmc 1/2t truck 6cylinder.Saw Sams had Duracell brand; but am sure there are Others...
Danny 1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Apples or Oranges! Since you have restricted yourself to $150 buy the highest CCA rated battery that $150 will cover. BTW battery warrantees are not worth the paper they are written on no matter what brand.
| | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | Just about any modern battery that fits in the battery tray.......will be just fine as long as the charging system is in good working order.
The battery in the old truck is under very light load once it’s past cranking the engine compared to the modern vehicle with power everything.
Back in the old days one CCA ( cold cranking amp) per cubic engine displacement ( 235) was a sizing guide line.........it’s easy to find a 600-800 cold crank amp battery in the trucks tray size of about $100.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You don't say if you are running 12 volts or 6. If its 12 volts about anything 600 CCA or higher will work. 6 volt get the best highest amp you can find to fit the case. I get mine from Sams club. They are good & the price is right. If it goes bad in less then 3 years they will replace it even without the receipt. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I'm happy with WalMart's 12-volt Maxx Everstart Group 35 battery. 640 CCA. Under $100, I think. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Aug 2001 Posts: 3,588 Moderator | | Moderator Joined: Aug 2001 Posts: 3,588 | I have been using Walmart batteries for years and have had good luck. They will last around five years. On vehicles that I don't drive very much, HF battery tenders work well for winter storage, such as lawn mowers or tractors. Batteries seem to last longer. Tenders are about 7 bucks.
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | It doesn't make it law....... but a recent report by Consumer Reports indicates that the Wally-World battery is as good as you can get for your money. I have always like and ran the DieHard, which on sale, is a good price and longer guarantee's. Still, I have two Wal-Mart batteries that are doing very well and the best part is if one goes bad you can now find a WalMart faster than a parts store! (Wal-Mart guarantee is shorter)
....still like my DieHards though! | | | | | Joined: Aug 2001 Posts: 3,588 Moderator | | Moderator Joined: Aug 2001 Posts: 3,588 | Dad bought a Diehard Forever battery in about 1980. Guaranteed to last as long as you own the vehicle. He got his money's worth and would get a new one free about every four years. Drove that truck till at least the mid 90's.
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | You don't say if you are running 12 volts or 6. If its 12 volts about anything 600 CCA or higher will work. 6 volt get the best highest amp you can find to fit the case. I get mine from Sams club. They are good & the price is right. If it goes bad in less then 3 years they will replace it even without the receipt. George In my original post I stated 58gmc 1/2t truck- so yes 12volts Thanks everyone for the advice
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I have been using Walmart batteries for years and have had good luck. They will last around five years.
Don I'm surprised you're happy with batteries that last only 5 years. I'm thinking more like 7 or 8. My original GM battery in my new van lasted 9.5 years. | | | | | Joined: Aug 2001 Posts: 3,588 Moderator | | Moderator Joined: Aug 2001 Posts: 3,588 | Five years is not bad cause they are only fully guaranteed for three years. Plus the wife works at Walmart and we get 10% off everything but food and drugs. I replace them as soon as they start acting up. And then it is used as a spare in the shop.
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | My old Interstate MT-26R 12v battery was starting to sound kinda slow. It's CCA is rated at 540. I installed a Wally World EverStart with a 650 CCA rating and OMG!! Turns over way tooooo fast :-).
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | My '48 has not started only 4 times in 26 years. I was out of gas twice. The battery was shot twice in my 6-volt days but not now. I probably change batteries more often than I need now but it makes me feel good going into a winter where I'll be driving on below zero days.
| | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | Believe it or not, the original Motorcraft battery in my 2000 Ferd Ranger lasted until 2014. It was probably still good when I replaced it, as the real problem I was to learn a few days later was the alternator. But I ended up with a new battery and a new alternator. Oh well...
Professional Novice
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | So what group battery for my truck?
58GMC 1/2t w GMC302.
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | decided to buy a Exide Extreme from Home Depot
Exide Extreme 24F 800 CCA @ 0* F 960 CCA @ 32* F 40 month warranty $99
seemed like a decent buy for the $$
