1 members (CuzzFuzz),
101
Mod | | | Forums66 Topics128,136 Posts1,056,425 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 37 | hi, hi have a lot of rust behind my runningboard supports on my '49 and one is totally busted off; should i grind the pop rivets off and clean it up and rebolt it or have a profeesional re pop rivet it. How would i pop rivet it? thanks for any advice, thanks ,mike | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Mike, I don't think those rivets would be considered 'pop rivets'. Unless you are going for original, I think bolting them back on would be perfectly acceptable. I think those rivets were either hot set rivets or cold set rivets...either one would be tough to find, not to mention the grizzled old ironworker to install them. Stuart | | | | | Joined: Mar 2005 Posts: 89 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 89 | How is the eaisest way to remove these "rivets"? | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | I think I would grind the head off and use a burp gun to drive them out. They can be stubborn as they sometimes have a 'belly' between mating pieces which makes them tough to drive out.
Stuart | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | After removing a couple dozen off my frame, I think the easiest way to to use a cutting torch to cut the head off flush. Put a punch in a vice grip and pound it. If it's hot, it only takes a hit or two. A grinder works, just takes a lot longer and harder to hit out I have found.
Good Luck. | | | | | Joined: Mar 2006 Posts: 113 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 113 | 1949chev34 - You'd need to hot rivet them to replicate the originals. Easier said than done. I welded nuts to the inside of my frame rails (because I did full length boxing plates).
Remember to buy 1st quality bolts!
Everything is different now...
| | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I am sure the cutting torch then punch is the easiest method to remove rivets, however it has been my experience that anytime I pick up my torch and move toward my bolt bad things happen. I always heat things up too much and then have to fix the screw-up. Grinding the head off may be a little harder but easier on the frame.
~Jim
