3 members (Lostbuthaulinass, Hotrod Lincoln, 2-Ton), 70 guests, and 3 robots.
Topics128,142
Posts1,056,485
Members48,441
1 Offline
hi, hi have a lot of rust behind my runningboard supports on my '49 and one is totally busted off; should i grind the pop rivets off and clean it up and rebolt it or have a profeesional re pop rivet it. How would i pop rivet it? thanks for any advice, thanks ,mike
Mike,
I don't think those rivets would be considered 'pop rivets'. Unless you are going for original, I think bolting them back on would be perfectly acceptable. I think those rivets were either hot set rivets or cold set rivets...either one would be tough to find, not to mention the grizzled old ironworker to install them. smile
Stuart
How is the eaisest way to remove these "rivets"?
I think I would grind the head off and use a burp gun to drive them out. They can be stubborn as they sometimes have a 'belly' between mating pieces which makes them tough to drive out.
Stuart
After removing a couple dozen off my frame, I think the easiest way to to use a cutting torch to cut the head off flush. Put a punch in a vice grip and pound it. If it's hot, it only takes a hit or two. A grinder works, just takes a lot longer and harder to hit out I have found.
Good Luck.
1949chev34 - You'd need to hot rivet them to replicate the originals. Easier said than done. I welded nuts to the inside of my frame rails (because I did full length boxing plates).
Remember to buy 1st quality bolts!
Everything is different now...
i drilled mine out
I am sure the cutting torch then punch is the easiest method to remove rivets, however it has been my experience that anytime I pick up my torch and move toward my bolt bad things happen. I always heat things up too much and then have to fix the screw-up.
Grinding the head off may be a little harder but easier on the frame.
~Jim
