3 members (klhansen, Nick in Manitou, TooMany2count), 322 guests, and 4 robots.
Topics128,089
Posts1,056,140
Members48,436
Choosing an after-market steering column to go with power steering conversion kit and small block with turbo 350 automatic. What length column to choose? Will a column shift for the automatic clear my ram-horn exhaust manifolds? 54 half ton
Length? I think they are around 30-31" but maybe someone knows for sure. My "aftermarket" was a 68 pickup column with turn signals and automatic shifter. I had no problems in my 52 panel and I am running ram horns. Another thought is the column's our of an "80"s (?) Chevy van with automatic and tilt. I have not used one but hear they work great and cost less.
.....I'm sure others will chime in to confirm or offer other ideas.
Redwing
Not your setup, but, for reference
I put a 455 Buick into a 51 panel truck. I used a 33 inch aftermarket chrome tilt column with
column shift. Cleared that big Buick valve cover....... close but no interference.
Also, used, a Kugel Komponents column shift linkage that was easy to install and adjust for the turbo 400.
