10 members (chevy51truck, Gdads51, Phak1, 52Carl, KEVINSKI, Woodcmiami, Peggy M, Wickedbass, Tinker5, 1 invisible), 40 guests, and 1 robot.
Topics128,036
Posts1,055,458
Members48,422
#1254706 02/12/2018 5:30 PM
I’m nearly getting to the point with my 49 Suburban project where I will be able to drive it
With the following specs is anyone able to take a shot at what Mpg it might return on the highway running at 70mph?
1949 Suburban
Stovebolt 261
Twin Carter W1 carbs
700r4 Box
Eaton H035 rear axle
Offenhauser intake
Fenton headers
6.50 16 Firestone
49 Suburban Project
What's the rear axle ratio?
1952 Chevrolet 3800 pickup
---All pictures---
16mpg. 🤷🏼‍♂️
Mike Attewell #1254759 02/12/2018 11:20 PM
At 70 MPH? 16-18.
Mike Attewell #1254770 02/13/2018 12:02 AM
5 Online: Content
At 70 MPH you will be impeded by aerodynamics. I doubt that you will get over 15 MPG.
Tire diameter and rear end gear ratio needs to be taken into consideration as well.
Mike Attewell #1254772 02/13/2018 12:05 AM
I have often obtained 18 mpg on an Interstate (55-60 mph) - 3.55 rear and 31.5" radial tires.
It drops to 15 mpg (or, less) above 60 mph.
The HO35 means nothing to me other than it would make a good password. A rear gear RATIO would mean a lot. I think my 37 Buick might be a good comparison as it has a 263ci engine, overdrive automatic, 4.11 gear, and 29" tall tires. The final drive in OD is 2.88---the same final drive most all overdrive vehicles had for years. I removed the sun visor, outside mirrors, and used 215 (narrow) radial tires inflated to 40psi. This bumped me to 16.5 mpg on a 3000 mile trip compared to the 12 mpg with the stock factory set up. A lot of work for not very satisfying results when one considers we put an LS3 engine in a customers 52 Suburban that clicks off 22-23 mpg and can melt the tires.
Evan
I will go with 14 to 16, the wind will kill it. If geared wrong, the overdrive will also kill any mileage. That engine should run in the 2300 to 2500 rpm range for decent mileage. It doesn't have the torque to pull 70 mph at a lower rpm like new, modern engines do.
13-16
Another quality post.
Real Trucks Rattle
