2 members (Ponchogl, Hush),
67
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 22 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 22 | I’m nearly getting to the point with my 49 Suburban project where I will be able to drive it
With the following specs is anyone able to take a shot at what Mpg it might return on the highway running at 70mph?
1949 Suburban Stovebolt 261 Twin Carter W1 carbs 700r4 Box Eaton H035 rear axle Offenhauser intake Fenton headers 6.50 16 Firestone
49 Suburban Project
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | What's the rear axle ratio? | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 |
| | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | | | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | At 70 MPH you will be impeded by aerodynamics. I doubt that you will get over 15 MPG. Tire diameter and rear end gear ratio needs to be taken into consideration as well.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I have often obtained 18 mpg on an Interstate (55-60 mph) - 3.55 rear and 31.5" radial tires.
It drops to 15 mpg (or, less) above 60 mph. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | The HO35 means nothing to me other than it would make a good password. A rear gear RATIO would mean a lot. I think my 37 Buick might be a good comparison as it has a 263ci engine, overdrive automatic, 4.11 gear, and 29" tall tires. The final drive in OD is 2.88---the same final drive most all overdrive vehicles had for years. I removed the sun visor, outside mirrors, and used 215 (narrow) radial tires inflated to 40psi. This bumped me to 16.5 mpg on a 3000 mile trip compared to the 12 mpg with the stock factory set up. A lot of work for not very satisfying results when one considers we put an LS3 engine in a customers 52 Suburban that clicks off 22-23 mpg and can melt the tires.
Evan
| | | | | Joined: Feb 2000 Posts: 5,194 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,194 | I will go with 14 to 16, the wind will kill it. If geared wrong, the overdrive will also kill any mileage. That engine should run in the 2300 to 2500 rpm range for decent mileage. It doesn't have the torque to pull 70 mph at a lower rpm like new, modern engines do. | | | | | Joined: Dec 2002 Posts: 3,438 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,438 |
