4 members (JW51, rfs56trk, Cosmo, 1 invisible),
119
Mod | | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 60 | I'd appreciate some help regarding my '51 3600 grill and some other trim questions. The truck is forest green. The grill is green and a cream color. Were these standard colors and were there any that were done with chrome? Also...my door / window trim has been repainted green. Underneath the drivers side I can see chrome. The passenger side doesn't have it. I'm now ceratin that the truck has some non-original parts on it but how should I restore it??? Is there a source for build sheets for Stovebolters? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Bob,
In 1949-1951, the "back splash" bar of the painted grille was white (with no pin stripe on the body-colored part of the bar).
Chrome grills were an available option in 1951.
Are you referring to the inside or outside door-window trim/molding? I think bright (stainless) molding was available in both locations in RPO 390 in 1951.
Build sheet? Receipt with options and accessories, maybe.
How should you restore it? It's your truck; it's your choice.
Tim | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | Welcome to the stovebolt bob. | | | | | Joined: Jan 2007 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 60 | Thanks Tim. The chrome trim was on the outside of the window...underneath some paint. I asked about the build sheet because I also have a '67 Firebird and was able to get a copy of the original factory build sheet from Pontiac Historical services. I want to restore this truck as close to original as possible but I might give in on some of the chrome features and switch it from 6v to 12volt. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Bob,
A build sheet does not seem to have come with these trucks. Also, the ID plate does not identify much more than truck size/series/GVW.
I'm with you regarding restoration of these trucks. Keeping them period correct can be a challenge, especially in finding out what is period correct. Finding parts is not too bad. There are a lot of opinions here and a lot of helpful people.
Regarding 6v vs 12v, if you are not going to add any modern accessories, the 6v is very reliable. First thing would be to get 1/0 (00) or 2/00 (00) battery cables from a big truck shop or a Tractor Supply Store and an Optima 6v battery (they are very powerful and they last a long time).
Good luck, Tim | | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | Bob, that window trim on your door is stainless. It was a option and I think came on deluxe cabs. Apparently your drivers door was replaced with a door that had the stainless trim and was painted to match the other door. See pic of my 53 before I had the vent window reinstalled. | | | | | Joined: Mar 2007 Posts: 12 Junior Member | | Junior Member Joined: Mar 2007 Posts: 12 | Bob,
I have a 51 5 window and my grille colors are the same as yours, green with creame. My grille looks original so I assume this is correct. | | | | | Joined: Jan 2007 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 60 | Thanks for the help...I'm pretty sure now that the truck was originally forest green with cream. Now I have to decide whether to refinish it as original or add some chrome...tough decision. Thanks, Bob | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | What I would like to see sometime is the inner part of the grill chromed (where the cream or white is) and the outer grill in paint. Just so there is a gleam of chrome, but not so much. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | FYI 1947-48 splash bars painted to match the body color. 1949-51 splash bars painted a cream color 1952-53 splash bars painted grey to match the painted hub caps and bumpers. Re. Classic Parts of America Catalog 1 Vol 3
~Jim
