6 members (sron48, 55shaker, Bill Hanlon, Lightholder's Dad, JW51, Forty9), 196 guests, and 7 robots.
Topics128,080
Posts1,055,956
Members48,430
#125437 04/07/2007 10:01 PM
I'd appreciate some help regarding my '51 3600 grill and some other trim questions. The truck is forest green. The grill is green and a cream color. Were these standard colors and were there any that were done with chrome? Also...my door / window trim has been repainted green. Underneath the drivers side I can see chrome. The passenger side doesn't have it. I'm now ceratin that the truck has some non-original parts on it but how should I restore it??? Is there a source for build sheets for Stovebolters?
#125438 04/07/2007 10:58 PM
Bob,
In 1949-1951, the "back splash" bar of the painted grille was white (with no pin stripe on the body-colored part of the bar).
Chrome grills were an available option in 1951.
Are you referring to the inside or outside door-window trim/molding? I think bright (stainless) molding was available in both locations in RPO 390 in 1951.
Build sheet? Receipt with options and accessories, maybe.
How should you restore it? It's your truck; it's your choice.
Tim
Welcome to the stovebolt bob.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
Thanks Tim. The chrome trim was on the outside of the window...underneath some paint. I asked about the build sheet because I also have a '67 Firebird and was able to get a copy of the original factory build sheet from Pontiac Historical services. I want to restore this truck as close to original as possible but I might give in on some of the chrome features and switch it from 6v to 12volt.
Bob,
A build sheet does not seem to have come with these trucks. Also, the ID plate does not identify much more than truck size/series/GVW.
I'm with you regarding restoration of these trucks. Keeping them period correct can be a challenge, especially in finding out what is period correct. Finding parts is not too bad. There are a lot of opinions here and a lot of helpful people.
Regarding 6v vs 12v, if you are not going to add any modern accessories, the 6v is very reliable. First thing would be to get 1/0 (00) or 2/00 (00) battery cables from a big truck shop or a Tractor Supply Store and an Optima 6v battery (they are very powerful and they last a long time).
Good luck,
Tim
Bob, that window trim on your door is stainless. It was a option and I think came on deluxe cabs. Apparently your drivers door was replaced with a door that had the stainless trim and was painted to match the other door. See pic of my 53 before I had the vent window reinstalled.
#125443 04/13/2007 12:24 PM
Junior Member
Junior Member
Bob,
I have a 51 5 window and my grille colors are the same as yours, green with creame. My grille looks original so I assume this is correct.
Thanks for the help...I'm pretty sure now that the truck was originally forest green with cream. Now I have to decide whether to refinish it as original or add some chrome...tough decision.
Bob
What I would like to see sometime is the inner part of the grill chromed (where the cream or white is) and the outer grill in paint. Just so there is a gleam of chrome, but not so much.
FYI
1947-48 splash bars painted to match the body color.
1949-51 splash bars painted a cream color
1952-53 splash bars painted grey to match the painted hub caps and bumpers.
Re. Classic Parts of America Catalog 1 Vol 3
~Jim
