| | | Forums66 Topics128,088 Posts1,055,993 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I wouldn't minde rebuilding the steering box while I'm rebuuilding the mechanicals. Can the steering column be removed from the bottom of the frame when its up on an average set of Walmart jack stands, or do you have to get it up higher like with a lift? Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jul 2006 Posts: 243 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 243 | denny im thinking about removing my cab for my rebuild, looks like to me the frame will have to be hiked up alot inorder to remove the column from the bottom... all i have is jack stands as well hope someone will chime in | | | | | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | It can be done that way. Basically, you manipulate the steering box down enough so that the top of the steering column come out of the firewall and then bring the whole assembly (column and steering box) up and out through the top.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin "Always do right. This will gratify some people and astonish the rest." - Mark Twain
| | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | I took my 53 steering column out while on ground, senting on the orginial tires and rims. | | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | I took mine out through the bottom with no problem. Mine sits higher though then pickups because of the taller tires. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Nawww, get out, are you guys are saying that it will come out even with out using jack stands???? You mean that it will slide forward enough to tilt up, how bout the hood will it clear that? Man, looking at it again and it sure don't look like it will go far enough forward to clear the firewall with out haveing it up pretty high. Well based on that I guess I'll put it on the list of things to be done. before I do the full cab off, frame up work this fall. Thanks Denny Graham Sanwich, IL
| | | | | Joined: Mar 2007 Posts: 12 Junior Member | | Junior Member Joined: Mar 2007 Posts: 12 | I PULLED MY OUT THROUGH THE BOTTOM WITHOUT JACK STANDS TOO. I HAD MY ENGINE AND FENDERS OFF THOUGH. I JUST UNBOLTED THE STEERING GEARBOX AND PULLED IT RIGHT OUT. EASY AS PIE! | | |
