1 members (klhansen), 70 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
I wouldn't minde rebuilding the steering box while I'm rebuuilding the mechanicals. Can the steering column be removed from the bottom of the frame when its up on an average set of Walmart jack stands, or do you have to get it up higher like with a lift?
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
denny im thinking about removing my cab for my rebuild, looks like to me the frame will have to be hiked up alot inorder to remove the column from the bottom... all i have is jack stands as well hope someone will chime in
It can be done that way. Basically, you manipulate the steering box down enough so that the top of the steering column come out of the firewall and then bring the whole assembly (column and steering box) up and out through the top.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin
"Always do right. This will gratify some people and astonish the rest." - Mark Twain
I took my 53 steering column out while on ground, senting on the orginial tires and rims.
I took mine out through the bottom with no problem. Mine sits higher though then pickups because of the taller tires.
Nawww, get out, are you guys are saying that it will come out even with out using jack stands????
You mean that it will slide forward enough to tilt up, how bout the hood will it clear that?
Man, looking at it again and it sure don't look like it will go far enough forward to clear the firewall with out haveing it up pretty high.
Well based on that I guess I'll put it on the list of things to be done. before I do the full cab off, frame up work this fall.
Denny Graham
Sanwich, IL
Denny G
Sandwich, IL
Denny Graham
Sanwich, IL
Denny G
Sandwich, IL
Junior Member
Junior Member
I PULLED MY OUT THROUGH THE BOTTOM WITHOUT JACK STANDS TOO. I HAD MY ENGINE AND FENDERS OFF THOUGH. I JUST UNBOLTED THE STEERING GEARBOX AND PULLED IT RIGHT OUT. EASY AS PIE!
