6 members (Bill Hanlon, fonz8261, Shaffer's1950, tclederman, Hotrod Lincoln, Charles in CA), 70 guests, and 3 robots.
Topics128,087
Posts1,056,376
Members48,442
V
VEW
Offline
V Offline
I'm working on getting my heater working in the '55 Grumman. It's never been connected since I've owned the truck, and the tag on the heater box says "6V", so I've been reluctant to diagnose it. I was pleasantly surprised yesterday when I tore it down to see the motor (2.3 amp) was a fairly new 12V, and the heater core was nearly new.
Now to wire it. I have a period type heater switch that I would like to use. It has the light in the switch that comes on when power flows through it. The only markings on it I can locate are "ARK-L". It has two spades in the back; one for motor and the other for power, with a resister.
So, can I use this for my 12V heater? How can I tell if it is a 6V switch, or does it matter?
Thanks for your help.
~ Victor
1957 3100 - moved on
The switch doesn't care if it's 6 or 12 volt. The indicator light however does. If it's a 6 volt light, it likely won't last long on 12 volts (but it may). One test would be to hook it up to 6 volts and see if it lights up sufficiently to see in daylight, if so it's likely a 6v light .
RonR
1970 340 Duster
1964 CJ5
Riding in the Passing Lane
The only variation between the 6 volt & 12 volt switch will be the resister. I would try it & watch the resister to see if it gets too hot. The original Grumman had a 2 speed motor. If it has a ground plus 2 more wires, it probably is a 2 speed motor. You would not need a resister. I have used ign. resisters for heater motors.
1972 Chevy c10 Cheyenne Super
V
VEW
Offline
V Offline
Thanks guys.
I was going to try to find an LED 12v bulb to put in it. You know what happens to those kind of switches over time.....the heat from the bulb melts the plastic knob.
The fan motor only has two wires: power and ground. The switch is three position: off, low, and hi. I don't know if the switch will control the speed of the fan motor or not. Probably doesn't matter anyway, as long as it supplies current to the motor. If I need heat, I can't imagine I will want to be turning it on "low" because it gets so hot in there smile
I'll hook it up and see what happens.
Thanks again.
~ Victor
Y
Y Offline
These guys are a great source fo r electrical components. I use them a lot. Saves money too. Del City
"I always win." Working mainly alone I do not let my trucks win a war. Maybe a battle here and there but never the war.
Robert
55.1 GMC 450 COE
51ish GMC Suburban
V
VEW
Offline
V Offline
Thanks Robert. I've seen Del City be recommend. The last time it was for quality wire at a good price. I think I've got them bookmarked.
~ Victor
