0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#1252197 01/23/2018 8:10 PM
I have a weeping carb and I would like to make it NOT weep,, are there any resources to rebuild these ? is this a diy project?
I have a 55 second gen!,, work in progress
1963 long bed step side driver
Just a guy who digs old trucks!
J Online: Content
The rebuild is easy if your carb is rebuildable in the first place.
Where is it weeping from? The air horn air horn to float bowl gasket?
(Oops, I assumed Rochester B when I read that. Do need to clarify which Rochester).
1951 3100
What carb? I'm doing a 2g at the moment. They are pretty easy, sounds like your fuel level is too high, (just guessing) could be sinking float or not adjusted correctly,needle damaged,bad gasket? Everything comes in the kit except a power valve. Its nice to have a sonic cleaner, but its not required. Its definitely DIY. There's usually a tag on one of the cover screws that tells you what carb it is, or if its missing hopefully its on the side of the float bowl. Otherwise you just have to match up parts by sight. Should be a number like mine which is 7011132 etc. Order a kit for the right carb, keep everything clean and just do it. Lots of youtubes on any carb you pick if you need them. Its nice to have a cookie baking sheet to disassemble it, take pictures as you go for reference. Parts will fall out at un-opportune times. One or two ball bearings inside, that most people get reversed, so just pay attention. If its a B I think those seeped when they were brand new. Careful adjustment of the float and drive it often will sometimes cure that.
1961 ford f500
1953 3100 five window (https://www.facebook.com/1953-Chevrolet-5-window-1533405913413610/)
1955-2 3200 big window (https://www.facebook.com/Leep3200/)
55yrs as a mechanic and retired. (kind of)
Mike's carburetor parts (http://www.carburetor-parts.com/) has tons of good info for identifying your carb, identifying your carb problem, and good DIY videos. I'm getting ready to tear my Roch B apart to see if I can fix the weeping (possibly float needle), stumbling on initial acceleration (possibly bad accelerator pump), and hard starting.
Sulli
It is a Rochester B and is weeping at the float bowl gasket its the one you can see that is just below the fuel line connection and runs all around the carb. The truck runs well starts fast , it has a miss but I think that is tune up related, I just want to dry up the fuel
There's a chance of finding a Rochester B that doesn't leak, but it's also theoretically possible that somewhere out there is Santa Claus, the Easter Bunny, or a unicorn.
The way to fix a leaky Rochester B is to make it a paperweight, and install a Carter carburetor.
I had two different Rochester B's rebuilt. Still leaked ECT. Bought a Carter at swap meet. Rebuilt it myself. Purrrerss like a kitten not one leak or issue. Just my 2 cents. Carter in, Rochester gone.
1950 Chevy 3100
I vote for the Carter install LOL. Unless you are trying to keep it stock for show purposes. The average Joe would not know the difference between a carter in there or a Rochester.
1961 ford f500
Carburetion specialist
C Online: Content
Jerry - I have seen several Rochester B's that were not leaking...............................................but they were sitting on a shelf! wink
Jon.
The Carburetor Shop
For the benefit of BoToepher and me, can you still have the manual choke and the throttle control with the Carter ?
Ron - - Dusty53
1954 Chevy 3604
Carter made a complete line of exact replacement carbs for Chevy- - - -and sold at least a million of them. Yes, they were made in manual and automatic choke models.
What is the Carter # for the 235? I know it’s probably been posted before, but it wouldn’t hurt to post again.🛠
C Online: Content
The Carburetor Shop
Almost 50 years' worth of Carter parts lists and technical data were stored in the motorhome my grandson was living in- - - - -the one that burned last Saturday. No, they didn't survive the fire. They covered the time frame from the 1920's to the mid-1960's.
well, At this rate I guess I should hunt up a fancy intake manifold and bolt on a two barrel Holley!
C Online: Content
Holleys don't leak?????
Several years ago, British Leyland was experimenting with different carbs and tried Holleys; they were rejected. Why? They ran great, but management determined that one pool under the engine was enough! blush grin wink
Jon
The Carburetor Shop
V
V Offline
Jon, did Carter (or anyone else) ever make a direct replacement for the Rochester Varajet 2bbl found on 75-84 Chevy 250's in trucks?
Thanks Jerry, good information to know. Looks like I better start saving my five's and ten's....
Ron - - Dusty53
1954 Chevy 3604
C Online: Content
Not to my knowledge.
Jon.
The Carburetor Shop
I rebuilt a Rochester B a few months ago. I was having trouble getting a Carter W-1 to idle properly (sometimes idling high, mostly stalling, hard starts). I plan to rebuild the Carter (I think the issues had something to do with ethanol) I took pictures and followed the filmstrip re-creation on Deve's site (courtesy of Brad Allen) There also is a link to Mike's Carburetors for a manual for the B. Once installed on my '47 1/2 ton with a 216, it ran way better - smooth acceleration and it idled at idle! Some good advice above. Take your time.
It's a small world, but I wouldn't want to paint it.
V
V Offline
Thanks Jon.
I also have a non leaking/weeping Roch B on my 49 216. I rebuilt it approx 4 yrs ago and so far it's performed very well.
With that said I tried to setup dual B's on a freshly rebuilt 235 and both weeped and had other problems. And even tho they looked practically identical on the exterior, they differed on the interior, especially in the accelerator pump. I punted on them...
Per Jon and other folks that have extensive knowledge on these carbs that fit these Stovebolt engines, the upper and lower housings can warp, perhaps from mismatched halves or incorrect rebuilding techniques, but once they warp there's practically no easy fix for them.
People have tried doubling up the gaskets and even used a sealer (not recommended) as fragments can clog up passages.
Good luck
