| | | Forums66 Topics128,023 Posts1,055,371 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | I just bought an old Jeep CJ5 that someone in the past swapped in a sbc. I'm told it is a 283 but I can't be sure. So my question is what do I look for on this motor to confirm it is a 283 and also determine what year it was manufactured?
1945 Chevrolet G 506 1.5 Ton Military 4X4 1967 Jeep Cj5 with 283 SBC
| | | | | Joined: Feb 2007 Posts: 112 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 112 | On the right front of the block just below the Cyl. head is a pad with stamped numbers. Need those numbers.
Or better yet the casting number.
The casting number is located on the driver's side, top rear of the engine block. The number on the front passenger side of the engine block will NOT tell you the displacement of the engine block
Tom | | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 |
