0 members (), 38 guests, and 4 robots.
Topics128,089
Posts1,056,004
Members48,430
#1251810 01/20/2018 11:48 PM
I have a set of non-stock aluminum rims on my truck from when I bought it, along with some radial tires. The tires are shot, and the rims are trashed. The previous owner gave me a set of original rims, but a couple of them have some significant pitting on the inside. Since I need to get new tires, I want to go with tubed tires on the original rims. I’ve cleaned them up to remove the corrosion, but the inner surface is still rough in some areas. I’m concerned that it’s rough enough to chafe the tubes. Should I be concerned about the roughness, and if so is it possible to repair them, maybe with an epoxy filler? Thanks.
1938 Chevy 1/2-ton
More info in the Gallery Forum
She looks good at 50 yards, and 35 miles per hour, on a dark night.
Hoff #1251831 01/21/2018 12:49 AM
H Online: Content
Cut a piece out of a big truck inner tube and stretch it over the rim so it's a snug fit in the drop center section. Bicycle rims used to have a band like that to prevent the spoke nuts from chafing inner tubes, on the ones I rode about 60 years ago, anyhow!
Hoff #1251841 01/21/2018 1:40 AM
Crusing in the Passing Lane
When one puts tube tires together, don't forget the liberal use of talcum powder, it solves a lot of problems, as well as inflating to peak pressure, then deflation to remove any wrinkles in the tube, then re-inflate.
Ed
Hoff #1251883 01/21/2018 5:15 AM
40 years ago I installed new tires on my 1935 Chevy wire wheels and I made two passes of Duct Tape over the spokes to prevent tube chaffing and they are still holding air!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Hoff #1251891 01/21/2018 9:55 AM
how about masking the bead surface off and using that Flex-Seal stuff that loudmouth salesman pitches on TV?
Hoff #1251896 01/21/2018 1:44 PM
If you are using tube flaps, the pitting on the rims should not be an issue.
Lots more pictures
Hoff #1251905 01/21/2018 3:09 PM
You can also get them powder coated super thick on the inside, it would seal and smooth at the same time.
Hoff #1251958 01/21/2018 10:47 PM
back yard wrench turner
Use tube flaps.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Hoff #1252034 01/22/2018 3:15 PM
Thanks gents. It’ll be a couple of months before I order the new tires. I’ll be sure to get the tube flaps.
1938 Chevy 1/2-ton
Hoff #1252090 01/23/2018 12:57 AM
If the bead surfaces are not pitted, you might be better off running radial tires without tubes.
