3 members (Lightholder's Dad, J Lucas, Hotrod Lincoln), 118 guests, and 3 robots.
Topics128,087
Posts1,056,338
Members48,442
#124927 03/08/2007 12:52 AM
I am currently down to the frame on my Chevy and I would like to do the best that I can the first time. My question if should I take the frame apart, ie.. removing the rivets and taking off the crossmembers and what not? What should I use to put the frame back to gether again? Would it be alright to weld or use bolts, or should I use only rivits? Is there any danger of the rust in the area under the joints spreading if I do not get it all out? Should I also use body filler to fill the divits left by the rust or just prime and paint. I may be nit picking but I would like to do the best possible.
Kenny B.
#124928 03/08/2007 2:24 AM
kenny I would not take the frame apart if it is in good condition IE no loose rivits or bad cross members rails so forth. Remove all nuts and bolts, sand blast and paint. that frame was made in a factory with tons of pressure putting those rivits into the frame cross members on a jig. If you take it all apart you gotta rivit all that stuff back together. that means from front to rear of the frame it has to be square and true. If you want a perfect frame. primer, filler, and primer and then top coat. lotta sanding inbetween primer and filer and primer.
jbennett
40 burb
#124929 03/08/2007 2:56 AM
Welcome Kenny-I am up around Cabot, north of Little Rock. Just like jbennet, I owouldn't reove anything off the frame either, just no good reason to go thru that much work, & those ribbets are pretty tough. No one will notice any rust pits once the truck is together, unless you are going for an all out show truck. Primer & paint. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#124930 03/09/2007 2:12 AM
So there should be no danger of the rust crawling out from under the joints if I do not get it all? Thanks. 64 I as you can see am from Marion I love AR but this side is to dang flat for my personal taste. I love the state once you get past Crowley's Ridge. I lived in Central MS before here.
Kenny B.
#124931 03/09/2007 3:07 AM
We have rolling hills here(in fact I live on the side of one), I am close to the foothills of the Ozarks. You can hit the rusty spots w/phosphoric acid or any concoction(Rust-Mort etc) you can find. If it is good paint it will not provide oxygen for rust to start again-GM never painted any frames, so any paint will be a huge improvement over stock.. Brian
