5 members (TexasJim50, Peggy M, TexasA&M48Truck, Bill Hanlon, 52Carl), 90 guests, and 2 robots.
Topics128,094
Posts1,056,058
Members48,433
#1247380 12/18/2017 11:18 PM
For the guys with V8s' what did you use for motor mounts? Thinking about a 350 and 700R4 in the '53.
1953 GMC 1-Ton Pickup with 350 and 700R4
Chad M #1247395 12/19/2017 12:30 AM
Crusing in the Passing Lane
Cardboard and glue like Jerry said.
Ed
Chad M #1247399 12/19/2017 12:53 AM
On my 1958 Chevy 3800 I used the original V8 front mounts with a manual transmission and the bell housing setting on the cross member rear mounts.
Chad M #1247407 12/19/2017 1:26 AM
"Thinking about a 350 and 700R4 in the '53."
1958?
hmm, in 1953, there were no original V8 motor mount locations?
Also, Chad M, you probably know that 1953 GMC vs Chevrolet-truck from motor mount locations are different (if an adapter is available for '53 Chevrolet)?
Chad M #1247440 12/19/2017 4:28 AM
I have a 52 panel and used the mounts that I bought from JimCarter but the mounts were made by Chassis Engineering. Loved the way they work but I believe your GMC is a little "longer" in the front....in other words the measurements from the front cross member would be different????
If you can look at my photobucket there are a few pictures.
Chad M #1247523 12/19/2017 10:39 PM
Sorry Chad, didn’t notice you were working on a 53.
Achipmunk #1247530 12/19/2017 11:57 PM
Achipmunk thank you. Are those the manifolds you used to clear the steering box?
Chad M #1247570 12/20/2017 4:39 AM
Chad, I used a set of ram horns off a 283.....a friend of mine gave them to me!
Moderated by  Dusty53
