1 members (baldeagle),
38
Mod | | | Forums66 Topics128,003 Posts1,055,244 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2014 Posts: 94 Shop Shark | | Shop Shark Joined: Oct 2014 Posts: 94 | I've seen ads for Cams & Re-Ring kits that both state for engines without PowerGlide...what's with No PG?
Also, is there any difference between NOS (new old stack) and NORS (new old replacement stock) ?
Thanks, Jim Hey...I jus noticed I graduated to "wrench fetcher" :-)
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Engines with Power Glide transmissions were only available in cars in the earlier years. They had slightly more HP due to the difference in the potential power loss with the automatic. They likely had a different cam profile and hydraulic lifters.
| | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | Powerglide cars ran 235 engines with hydraulic valve lifters. Trucks (except for big rigs) ran 216's with solid lifters.
NOS and NORS are usually parts intended for the same application. NORS is sometimes used to indicate a non-GM part manufactured back when the vehicles were daily drivers as a replacement for a factory part- - - -Like Blue Streak or Standard brand ignition products instead of Delco etc. Jerry
| | | | | Joined: Feb 2000 Posts: 5,190 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,190 | NOS is a New Old Stock, GM part, something that stayed on the parts shelf that never sold. NORS is an New Old Replacement Stock part from some vender other then GM that never sold and stayed on the shelf.
Both are worth using if they are not rusted or have rubber in them. The types of rubber used back then don't seem to last. Also be careful when shopping, some " NOS " parts are actually returned parts that may not have fit or had some sort of defect in them. Case in point, I purchased a set of NOS tie-rod ends for my '37, they looked new and the box was in good shape, but one of them wouldn't turn smoothly. No amount of grease would free it up. When I really looked at the parts, I could see where they were installed at one time.
Joe | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | NOS does not mean used, as evidently were those tie rods that were sold to you under false pretenses.
As Jerry said NORS means they where made back in the day when the car, truck, was on the road during it's first life.
NORS doe not mean junk or gold.
What is important is does the part have a trusted quality brand name 50 years ago, as Blue Streak or some cheap low quality junk.
And a good point was mentioned that some NOS parts can be in poor condition depending on the materials made from and how they were stored for all those years. Jeffrey | | |
