| | | Forums66 Topics128,034 Posts1,055,536 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 1,453 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,453 | Need to get an engine mount rebuilt as unable to find a decent used one & no old stock to be found for my '60 C10 / 235. Anybody have a reference, prefer west coast.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | East Coast but I believe Steele Rubber Products does some of this. Won't be cheap though, not from them......Parts houses no help? | | | | | Joined: Jan 2014 Posts: 3,677 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,677 | Is this what you need?https://www.rockauto.com/en/catalog/chevrolet,1960,c10+pickup,3.8l+235cid+l6,1489472,engine,motor+mount,5552
1951 3100
| | | | | Joined: Sep 2011 Posts: 1,453 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,453 | I'll have to look the number up again, have checked a couple years ago & couldn't find anything but used. The ones shown rock auto etc are side mounts for V8. This is a rectangular pad bolts to timing cover. Might be the same mount as used w/ horseshoe bracket on V8 in these years.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | As mentioned, Steele Rubber Co. I had a pair of 1960 GMC V6 motor mounts revulcanized by them for $100. These were very basic rectangular rubber blocks onto a flat plate, so depending on what yours look like will determine cost. Many times there are other mounts, for something else, that can work. Is the mount just a bushing and washer stackup? If we see a pic of yours we can eliminate a bunch of false leads. Several sites show the 3 hole mount for 235. I guess that is the side mount. Can you switch to side mount? Is 1960 different from 1961 and up 235 mounts? Have you checked 55-59? Anything here?Most of the time an old part number does not do any good anymore. You have to dig the internet.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | BC, The Filling Station lists your part as PN 70-1828 and in my old catalog has a price of $65.80 for "revulcanizing".
When I restored my '36 Chevy pickup in the early 1970s the side engine mounts needed "revulcanizing". In looking at them it looked like 1/8" steel plate was crimped around a captured rubber pad. I heated the metal to uncrimp it. That had the effect of incinerating the old rubber, but so what? I duplicated the size and shape of the original rubber part and crimped the metal parts back together cold in my vise and 40+ years later that home repair is holding up fine.
Ray
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | "It's $106 plus ship now."
It shouldn't be too tough to figure out a way around that and save a quick $106 + postage. This is an example of when having a little ingenuity pays off.
Ray
| | | | | Joined: Sep 2011 Posts: 1,453 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,453 | Had missed that on my Filling Station CD. O.E. part # is 3769767, mount is the same for V8 in these years that use the horseshoe bracket to the front of the engine. Rock auto, classic parts, etc all show the mount to the side of V8 as '63 up would use. Thanks for all the input.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Mounts from scratch are easily made with neoprene snow plow stock, comes 4" wide by 1" thick by lengths, if one can use flat pieces. Not available in Florida, etc.
Ed
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I actually did what you need. I used the "plates" from the original, found two "hockey puck" rubber pieces that had a center hole and the right thickness. You can also use a rectangular block. I don't think I could find one, can't remember. Anyway I put new bolts down thru the horseshoe mount, thru the plate, thru the rubber, thru the plate, thru the frame piece and used washers and nuts. (approximate method from memory). As long as the durometer is correct, it's a done deal. If you need to make new flat plates, make new flat plates.
