| | | Forums66 Topics128,009 Posts1,055,291 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 143 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 143 | Hello all. I was hoping someone would have some insight on an inline 6 I have in a 66 C10 with 3 speed. I'm unsure if the motor is original to the truck but as far as I understand, 1966 was the first year for the 250. The numbers I have been able to gleam from the block is the block casting 3877178C which just tells me it is either a 230 or 250 (although I don't know what the C means). The code near the distributor is F0219FA. I can find just about every suffix code online other than FA. So far I can determine it was made in Flint on February 19th from that code. I can't seem to find the date code near the starter. The only other number I've found is CON2. I haven't been able to make out the shape of the pistons which would at least tell me if it was a 230 or 250. Any info would be appreciated. Thanks. | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | A borescope that will fit through the spark plug holes costs about 30 bucks on ebay. I use mine all the time for inspecting engines, and it even fits down barrels as small as .22 to inspect the condition of the rifles I buy. Mine has a mirror attachment that lets me put it through a hole and look sideways. Jerry
| | | | | Joined: Apr 2008 Posts: 143 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 143 | Thanks Hotrod. That's actually on the list of soon to buy toys. | | | | | Joined: Jul 2000 Posts: 2,187 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,187 | I believe 67 was the first year for the 250. Oops. GM Heritage site says I'm wrong. Looks like my source, John Gunnell was wrong too Info Kit
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Hey Jerry, can you let us know the specifics of bore scope (manufacturer name, model #) and what/how you hook it up to to see what you're looking at?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Someone posted a link to a nice borescope (maybe Jerry?) I'll check tomorrow what brand (I bought one and it is cool/helpful). | | | | | Joined: Apr 2008 Posts: 143 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 143 | Believe it or not I found the original Protection Plan book for this truck which lists the original engine number as being F0112TA. This means the truck's original engine is no longer in it. As for a bore scope, I will probably be ordering a Goodan brand 1200p tonight. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Found the FA code, it's for a '56 230 or a '66-'67 250 from full size Passenger car with manual transmission.
Bill Burmeister | | | | | Joined: Apr 2008 Posts: 143 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 143 | Thanks Longbox! That's good to know. May I ask where you found this info? | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | My borescope was an Ebay purchase, but I don't remember the brand name offhand. It plugs into the USB port on my laptop and projects its image onto the monitor. I did a little shopping for the smallest possible diameter of lens (5 MM) so I could inspect chambers and barrels of small bore rifles. A somewhat larger lens would probably give a sharper focus for engine inspections if you don't need to access very small holes. There's a wide variety of choices and prices, and like anything else, "Ya gets what ya pays for!"
When the borescope and the headspace gauges come out at a gun shop, the prices come tumbling down, on occasion! Jerry
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Thanks Longbox! That's good to know. May I ask where you found this info? GM Heritage Center Archive.
Bill Burmeister | | | | | Joined: Apr 2008 Posts: 143 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 143 | | | |
