5 members (tclederman, gswbbc, Uncles51, dwreills, Peggy M), 83 guests, and 2 robots.
Topics128,035
Posts1,055,446
Members48,422
#1244644 11/25/2017 10:40 PM
What's the best way to lower the hight of the truck suspension a 56.3100 with orignal springs.Don't want to start swapping axes .Could do with losing about 2 inch if possible.Thanks.
Stooby #1244712 11/26/2017 11:08 PM
My '37 uses different shackle length front and rear, so I installed short front ones on the rear, then bought even shorter ones for the front. It was cheap and easy way to lower 1" or slightly more.
Contact Sid at droppedaxle.com
He bent my front axle 4” for a good price! Does great work.
Chris
If all you want is 2 inches, and you are willing to do it with springs only, then you can also have a spring blacksmith re-shape the leafs. It's a simple process and about half the price of new springs.
~ Dave
