| | | Forums66 Topics128,035 Posts1,055,559 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2017 Posts: 76 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 76 | What's the best way to lower the hight of the truck suspension a 56.3100 with orignal springs.Don't want to start swapping axes .Could do with losing about 2 inch if possible.Thanks. | | | | | Joined: Feb 2000 Posts: 5,198 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,198 | My '37 uses different shackle length front and rear, so I installed short front ones on the rear, then bought even shorter ones for the front. It was cheap and easy way to lower 1" or slightly more. | | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | Contact Sid at droppedaxle.com
He bent my front axle 4” for a good price! Does great work.
Chris | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | If all you want is 2 inches, and you are willing to do it with springs only, then you can also have a spring blacksmith re-shape the leafs. It's a simple process and about half the price of new springs.
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | |
